Activity Forums VEGAS Pro Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
  • Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
    Posted by Adrian Komorek on November 14, 2015 at 1:08 pm
    I just uphraded my from Windows 7 Pro to Windows 10 Pro and Sony Vegas 13 Pro woulden’t open anymore, I trieded ALL solutions outthere, updating drivers, disabling graphic card, running as a admin, cahing combality, both, it just woulden’t open, it seems to crash when it’s loading up Installing DirectX plugs-ins.
    Extra Information
    File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
    File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
    File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
    File: C:\Users\Adrian\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 290) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\WINDOWS\SYSTEM32\vorbis.acm
    Fault Address: 0x00007FF9B8241F4F
    Fault Offset: 0x0000000000001F4F
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 290) 64-bit
    Process Description: Vegas Pro
    Geoff Candy replied 8 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    November 14, 2015 at 6:08 pm
    [Adrian Komorek] ” Process Version: Version 13.0 (Build 290) 64-bit”
    Try updating to Build 453 and see if it works.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    November 25, 2015 at 12:51 am
    Because you not using the latest version of Vegas 13 optimized for
    Windows 10. Download version 453 from the Sony Creative website…
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Rob Lindsay
    March 1, 2018 at 2:52 am
    I do use ver 453, and it still freezes on opening when it hits the Directx part of the start up. This last time it took 5 attempts. Froze at Directx each time and each time I had to Crl alt del and start over.
    is there a fix?
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • John Rofrano
    March 3, 2018 at 12:07 am
    I’m guessing it’s a graphics driver problem. Try updating to the latest drivers for your card. If you are at the latest drivers, try downgrading to older drivers.
    ~jr
    http://www.vasstsoftware.com
  • Geoff Candy
    March 5, 2018 at 9:56 pm
    Version 453 is the last version from Magix and does not contain dolby AC Pro. If you are currently using the last version from Sony then carefully copy out the dolby pro plugin folder & copy it in to the newer V13.
    More info is available on the magix vegas forum. Search missing ‘dolby pro’
    G
  • Rob Lindsay
    March 5, 2018 at 11:42 pm
    Sorry, why would Dolby AC pro help with a freeze issue around DirectX initialization?
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Rob Lindsay
    March 12, 2018 at 2:45 am
    Installed ver 545 and it still freezes at Initializing DirectX.
    I’m at a loss at what to do.
    Vegas 13.453
    Dell Windows 10
    Intel6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Geoff Candy
    March 12, 2018 at 12:37 pm
    I seem to recall that trying to install VP13 onto W10 I had problems with the installation. Initially I gave up on VP and loaded DVDA as I normally edit in Edius. DVDA loaded and installed some .net components. On trying to install VP13 again it went in smoothly. VP13 last Sony version.
    I can understand your frustration.
