Activity › Forums › VEGAS Pro › Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
  • Sony Vegas 13 Pro crashes on Installing DirectX plug-ins WIndows 10
    Posted by Rob Lindsay on November 22, 2018 at 7:12 pm
    I am still having this problem. After 10 attempts to open the program with each freezing at “Installing DirectX”, I am hoping someone else has found a way to fix this bug, since magix has no cust service.
    Thanks for any ideas,
    Rob
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
    Steve Rhoden replied 7 years, 10 months ago 3 Members · 4 Replies
  • Mike Kujbida
    November 23, 2018 at 12:24 pm
  • Steve Rhoden
    November 28, 2018 at 12:20 am
    This is exactly what you are looking for in Mike’s recommendation:
    11. HANGING ON DIRECTX PLUG-INS?
    If VEGAS Pro hangs when it says “Initializing DirectX plug-ins” at the lower left of the splash screen, try the following:
    1. Right-click on the launch icon.
    2. Select “Properties”, then the “Shortcut” tab.
    3. Add the following command line argument outside of the quotes in the “Target” field: /NODXGROVEL (Be sure to include a space between the last quote and the forward slash) An example for VEGAS Pro 15.0 would typically look like this:
    “C:\Program Files\VEGAS\VEGAS Pro 15.0\vegas150.exe” /NODXGROVEL
    4. Select “Apply” then “OK”
    5. If it doesn’t help then change it back when you have finally got VEGAS Pro to start reliably.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Rob Lindsay
    November 29, 2018 at 12:51 am
    Thank you — it seems to launch a little better now, although it still took 2-3 tries (sigh).
    It is making Premiere look better and better…
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Steve Rhoden
    November 29, 2018 at 2:31 am
    No, No, No, dont be fooled. Premiere is no holy grail alternative.
    The grass always seems greener on the other side, untill you cross over
    and then realize it is not.
