Activity Forums VEGAS Pro Sony Vegas 12 Resonant filter on audio not always working
  • Sony Vegas 12 Resonant filter on audio not always working
    Posted by Michael Gibrall on September 14, 2013 at 3:15 am
    Hello all.
    Using Sony Vegas 12 Pro.
    I keep having this bizarre thing happening.
    I have on my timeline a series of audio clips that have a resonant filter on them; specifically a “Teenage Late Night Radio by the Bed” effect that sounds like someone over the phone.
    On my timeline it sounds correct.
    If I render, it will be as if there is no effect whatsoever on the audio.
    If I move the clips to another audio track it may work on a render, but I just had a render fail to have the effect work.
    Am I missing something?
    Thanks in advance.
    Michael Gibrall replied 12 years, 11 months ago 2 Members · 4 Replies
  • Graham Bernard
    September 14, 2013 at 6:07 am
    Well, to summarise, the SFx works on a Track but not on another.
    Presently I can’t repro this. I have the effect being heard on rendered output
    You are going to need to supply ScreenGrabs of your Workflow and just where are adding your SFxs.
    Cheers
    Grazie
  • Michael Gibrall
    September 15, 2013 at 1:24 am
    Bottom left of image.
  • Graham Bernard
    September 15, 2013 at 8:02 am
    That’s very helpful. Now, where along that Timeline AREN’T you hearing on render? You need to be specific.
    G
  • Michael Gibrall
    September 15, 2013 at 3:34 pm
    The left area, all those clips have the effect. On the same track to the right, they do not.
    Sometimes during a render, the effect works for the clips to the left. Sometimes, it doesn’t.
    I’ve moved the clips with the effect to another audio track and it will work if I render. For a while. Eventually, it’ll stop working when I render.
    Mind you I always hear the effect when playing back on the timeline. It’s sometimes a render won’t take.
    Maybe I should create an audio track only for the clips with the effect?
    I guess another alternative is to render just the clips as a wav or aiff and drop them into the timeline?
