Sony Vegas 12: Render As -> “An error occurred while creating the media file . Exception thrown by method called”
Today something weird started happening with Vegas 12. I was mucking about in my recent project and when I finished I pressed “Render As” and then this error came up:
It’s been around 2 months since I installed Windows 8. Vegas has been working flawlessly until now.
I tried rendering different projects (both empty and with media files), restarting and reinstalling Vegas but the error still came up. Then I tried Ctrl + M (which means Render To New Track) and then this error came up:An error occurred during the current operation. An exception was thrown by a type’s initializer (.cctor).
I also Googled on the first error (the second one didn’t give any good results) and came to the conclusion that it might be the K-Lite Codec pack I had installed MONTHS ago. I tried uninstalling the pack and removing it from the registry as well but no dice.
Some users had said that only reinstalling Windows helped. So I tried Windows 8’s Refresh; and it worked!
I carefully selected programs I wanted to install using ninite.com – and I accidentally selected MPC with decoders (included were MPC). After installing everything Vegas no longer worked, same error.So I did a second reformat, went to MPC’s website and installed it without K-Lite (I presume the installer doesn’t install codecs, since it didn’t give any information on it or anything). Vegas 12 still worked. I preceded to install various Adobe software (Photoshop, Audition, Premiere, After Effects, Media Encoder, Illustrator, Lightroom), DayZ Commander, Mumble (1.2.4 beta), Fraps and other software I’m not completely sure of.
I rendered my project again. I opened the file and then I noticed there were some black frames in the clip. I re-rendered everything but it got worse. Blacks frames to and fro, glitching and other shit.
Then I tried a third time. The error came back.Now, to recap, I have not installed any codecs; only drivers and various software (there’s a full list below). What the HELL is going on? I’m beginning to speculate it’s Windows Update doing some hidden updates, but I doubt that’s even possible.
List of installed programs as of 2013-01-11 (in the time span of 6 hours or so)
Start Menu\Programs\Adobe Master Collection CS6 Public:Start Menu\Programs\Adobe Master Collection CS6 Public
Start Menu\Programs\ASUS Xonar D1 Audio Public:Start Menu\Programs\ASUS Xonar D1 Audio Public
Start Menu\Programs\Dropbox David\David:Start Menu\Programs\Dropbox David\David
Start Menu\Programs\Foxit Reader Public:Start Menu\Programs\Foxit Reader Public
Start Menu\Programs\Fraps Public:Start Menu\Programs\Fraps Public
Start Menu\Programs\Maintenance Default:Start Menu\Programs\Maintenance Default
Start Menu\Programs\Maintenance Public:Start Menu\Programs\Maintenance Public
Start Menu\Programs\Maintenance David\David:Start Menu\Programs\Maintenance David\David
Start Menu\Programs\MPC-HC x64 Public:Start Menu\Programs\MPC-HC x64 Public
Start Menu\Programs\Mumble Public:Start Menu\Programs\Mumble Public
Start Menu\Programs\Notepad++ Public:Start Menu\Programs\Notepad++ Public
Start Menu\Programs\Notepad++ David\David:Start Menu\Programs\Notepad++ David\David
Start Menu\Programs\NVIDIA Corporation Public:Start Menu\Programs\NVIDIA Corporation Public
Start Menu\Programs\NVIDIA Corporation\3D Vision Public:Start Menu\Programs\NVIDIA Corporation\3D Vision Public
Start Menu\Programs\Sony Public:Start Menu\Programs\Sony Public
Start Menu\Programs\Sony\Vegas Pro 12.0 Public:Start Menu\Programs\Sony\Vegas Pro 12.0 Public
Start Menu\Programs\Stardock Public:Start Menu\Programs\Stardock Public
Start Menu\Programs\Stardock\Fences Public:Start Menu\Programs\Stardock\Fences Public
Start Menu\Programs\StartUp Public:Start Menu\Programs\StartUp Public
Start Menu\Programs\Startup David\David:Start Menu\Programs\Startup David\David
Start Menu\Programs\Steam Public:Start Menu\Programs\Steam Public
Start Menu\Programs\System Tools Default:Start Menu\Programs\System Tools Default
Start Menu\Programs\System Tools Public:Start Menu\Programs\System Tools Public
Start Menu\Programs\System Tools David\David:Start Menu\Programs\System Tools David\David
Start Menu\Programs\Tablet PC Public:Start Menu\Programs\Tablet PC Public
Start Menu\Programs\WinRAR Public:Start Menu\Programs\WinRAR Public
Start Menu\Programs\WinRAR David\David:Start Menu\Programs\WinRAR David\David(List is in no particular order I presume since Windows only dates programs by Year/Month/Day and not hours/minutes)
And inside HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32
I presume this is were codecs which are installed are located.Addiotional information:
##### System Information #####OS: Windows 8 Pro (6.02.9200)
DirectX: 9.0c + 10 + 10.1 + 11
CPU name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU speed: 3293MHz
Memory: 4096MB
Screen size: 1920×1200 (32bits)
Video card: NVIDIA GeForce GTX 460
VendorID: 10de, DeviceID: 0e22
Video mem: 768MB
Video driver: nvd3dumx,nvwgf2umx,nvwgf2umx (Version 9.18.13.697) (10-2-2012)
Audio device: High Definition Audio Device
Audio driver: HdAudio.sys (Version 6.2.9200.16384) (7-25-2012)https://pastebin.com/6NF46VBp (Codec tweak tool)
