Activity Forums VEGAS Pro Sony Vegas 12 Machine Recommondation
  • Sony Vegas 12 Machine Recommondation
    Posted by Gray Kinney on February 25, 2013 at 6:10 pm
    This is my first post here, and appreciate your time.
    I did look at some previous posts on machine specs for PC, but was hoping to get a more up to date recommendation.
    My boss is using Vegas 12 and having rendering issues (White screens and lockups). I know that I need to get him a good GPU card for this machine but before I do that I was considering a full editing machine. He is using a HP Machine that is stock from HP. I think it is an i6 processor but need to check.
    So… If you could buy anything say up to 3k, what would you get?
    Motherboard:
    CPU:
    RAM:
    Video Card(s)
    Hard Drive(s)
    Raid? (y/n)
    I did recommend one of these cards from Sony’s site:
    https://www.sonycreativesoftware.com/vegaspro/gpuacceleration?keycode=9500-9500
    Thanks in advance.
    Gray Kinney replied 13 years, 6 months ago 4 Members · 11 Replies
  • 11 Replies
  • Dave Osbun
    February 25, 2013 at 7:13 pm
    Mobo: Asus P8Z77-V Pro
    Processor: Intel Core i7 3770k (3.5Ghz)
    Memory: G-Skill Ares DDR3 1866 16gb (2 sticks of 8gb ea) F3-1866C10D-16GAB (times 2 for 32gb RAM)note: this is low profile memory if you plan on using a large aftermarket cpu cooler
    Video Card: any nVidia Quadro 4000 card
    System hard drive: Samsung 840 Pro 256gb SSD (MZ-7PD256BW)
    RAID drives: Seagate Barracuda SATAIII (6gb/s) 7200rpm or equivalent
    Power Supply: CORSAIR HX Series HX750 750W Gold
    Dave
  • Gray Kinney
    February 25, 2013 at 7:38 pm
    Thank you very much Dave, this is just what I needed.
    One follow up: My boss is carrying around his projects on an external drive so he does not need to copy to the local machine(s). (He works at home and here on Vegas.)
    Is there enough throughput to and from these drives for HD quality projects?
    Thanks again.
  • Dave Osbun
    February 25, 2013 at 8:58 pm
    It depends on what interface the hard drives are using (eSata, Firewire, USB 3.0, etc.). Most external drives are USB 2.0, so I would copy the project info (and video clips) to the RAID. If the external drive was eSATA, it’s probably best to still copy them to the RAID since performance will be better. I do own a Lacie external drive (eSATA, Firewire and USB) and have used it for video editing with Vegas Pro 8, but you’ll get better performance just using the SATA3 RAID drives.
    I probably should have also added: you should have another SATA3 7200rpm hard drive, to keep other computer programs on, and the Vegas Pro project files. The RAID data should strictly be for video. I personally have a 1tb Seagate Barricuda 7200rpm SATA3 drive. They are cheap (under $90) and fast!
    Dave
  • Gray Kinney
    February 25, 2013 at 9:16 pm
    I believe he is using USB3.0
    Further investigations is showing problems when he is using New Blue FX Titler Pro 2 specifically.
    Thanks again for your feedback.
  • John Rofrano
    February 26, 2013 at 11:45 am
    [Gray Kinney] “I did look at some previous posts on machine specs for PC, but was hoping to get a more up to date recommendation.”
    I just build this Hex Core system a few months ago and it is very stable with Vegas Pro 12.0:
    Intel Hex Core Video Editing Workstation
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Osbun
    February 26, 2013 at 1:55 pm
    The only major difference between the hardware I listed and your new system specs is the Intel i7 processor, yours being Sandy Bridge and the one I listed being Ivy Bridge and the motherboard chipset, with the Z77 chipset, which is designed to fully take advantage of the Ivy Bridge architecture.
    If you do build a system, make sure you know about BIOS configuration, since you have to make a change to the Memory Profile in the BIOS to take advantage of the newer high-speed memory modules. By default it will usually run at 1333 speed (even if the memory & motherboard are advertised to run at 1600). You’ll want to choose XMP Profile 1, in the BIOS Memory Profile and this will make the memory modules I listed run at 1866.
    Dave
  • Mike Thomas ii
    February 26, 2013 at 6:20 pm
    I am currently running this setup for Vegas…my build was under 3k
    Windows 7 Pro x64
    Cooler Master Storm Trooper case
    Intel i7-3770K CPU @4.22GHz
    Asus P8Z77-V Deluxe mobo
    EVGA GeForce GTX 560 2GB GPU
    Corsair Vengeance 16GB 1866 RAM
    Corsair H100i CPU Liquid Cooler
    Corsair HX750 PSU
    Corsair Force GS 240GB SSD
    Western Digital 1TB Black HDD
    Western Digital 2TB Green HDD
    LG CH12LS28 Blu-Ray drive
    Enermax Vegas Trios LED fans (x2)
    Samsung SyncMaster 24″ SA300
    Razor BlackWidow Elite 2013 keys
    Razor DeathAdder 2013 mouse
  • Dave Osbun
    February 26, 2013 at 8:06 pm
    I built my system for my 10 year old son, as his Christmas present this past December. I run Vegas Pro 12 on it, but i’m not a pro editor, only doing it for personal projects (ie- non-paid work), and my computer flies. My render times are the same ratio as my timeline length, with my 1080 footage rendered for internet use (YouTube 1080), and I only spent $1000, and that includes a 23″ IPS monitor.
    If the current 3rd gen i7 processors significantly decrease render times, it’s hard to justify spending twice the amount (except for you pros, where saving any time is a big priority).
    Dave
    Intel i5 3570K Ivy Bridge 3.40GHz quad core
    Asus P8Z77V-LK
    16gb RAM
    ATI Radeon HD7850 2gb
    Crucial M4 SSD + Seagate Barricuda 7200rpm
    Windows 7 Pro 64
  • Gray Kinney
    February 27, 2013 at 5:20 pm
    Thank you Dave, I had not seen that before. Ill be sure to check it.
    Thanks Again!
  • Gray Kinney
    February 27, 2013 at 5:21 pm
    Thanks for the input Mike, this is all very helpful.
