Activity Forums VEGAS Pro Sony Vegas 12 – Cropping away the left and right sides.
  • Sony Vegas 12 – Cropping away the left and right sides.
    Posted by Ben Gem on March 16, 2014 at 7:56 pm
    Like the title says, Im have trouble with unintentional cropping of my video when rendering, only the sides. Why is this happening?
    The project is in 1280×720 (25frames, 1.0000 (Square))
    Render settings:
    Correct size:
    Rendered size:
    John Rofrano replied 12 years, 5 months ago 3 Members · 4 Replies
  • Phil Peacock
    March 17, 2014 at 10:05 am
    Very hard to see what is happening here as the image is very dark. Ratio looks a bit odd though. Turn off ‘Allow source to adjust frame size’ and see if that helps. If not, let us know the details of the original footage.
  • Ben Gem
    March 17, 2014 at 4:36 pm
    I tried and turned off the ‘Allow source to adjust frame size’ but unfortunately it did not help.
    I’m totally lost, what could be causing this weird problem?
  • Phil Peacock
    March 19, 2014 at 9:20 am
    What are the specs of your original footage?
  • John Rofrano
    March 21, 2014 at 11:07 am
    What player are you using? Maybe it’s a player problem?
    Drop the rendered footage back onto the Vegas Pro timeline and see if you have the same problem.
    It might also help if you post a screenshot of your project properties.
    BTW, it’s not cropping… it’s stretching.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
