Sony Vegas 11 will not render .mp4 files.
Posted by Zach Mcbrown on November 5, 2011 at 3:03 amWhenever I try to render a .mp4 file in Vegas 11, it says “The reason for the error cannot be determined.” Anything to fix this?
Cristian Grigore replied 9 years, 4 months ago 14 Members · 24 Replies -
John Rofrano
November 5, 2011 at 12:08 pm[Zach McBrown] “Whenever I try to render a .mp4 file in Vegas 11, it says “The reason for the error cannot be determined.” Anything to fix this?”
Does it happen with both Sony AVC and MainConcept AVC? Do you have any “codec-paks” installed? This should just work if your PC is clean.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Zach Mcbrown
November 7, 2011 at 8:23 pmIt is just the MainConcept AVC. I have K-Lite Codec Pack installed on my computer for Windows Media Player, but not directly to Sony Vegas.
Steven Broido
November 9, 2011 at 4:36 pmWe are running a trial version of 11 now and experienced the same problem while rendering to Main Concept MP4. Would a clean uninstall and reinstall help? Is this related to 32-bit vs 64-bit versions of Vegas?
Will try Sony AVC codec next…
Hope we get this figured out soon as we render everything out in MainConcept now.
Thx!
S
John Rofrano
November 9, 2011 at 4:51 pm[Zach McBrown] “I have K-Lite Codec Pack installed on my computer for Windows Media Player, but not directly to Sony Vegas.”
More than likely this is what’s causing the problem. You should never install any codec-pak to a computer that you edit video with. It messes things up (as you have seen). You can try uninstalling it and re-installing Vegas but there is no guarantee that it will uninstall cleanly. Worth a try though.
~jr
John Rofrano
November 9, 2011 at 4:53 pm[Steven Broido] “We are running a trial version of 11 now and experienced the same problem while rendering to Main Concept MP4. Would a clean uninstall and reinstall help? Is this related to 32-bit vs 64-bit versions of Vegas?”
It depends on if you also have any codec-paks installed. In general, you don’t want to use these on a video editing computer.
~jr
David Wilson
November 12, 2011 at 2:13 amI cant get Vegas 11 pro to show me the sony avc options when I render. Keep having to use main concept for now, how can a sony product keep having so much trouble with their own video format? Sometimes it shows up, sometimes it doesn’t. does it have to do with the type of footage that is on the timeline? Anyone know? I have tried about everything including a clean install, but it does the same thing.
David M. Wilson, SCVU
Owner of CWC Video Production of Chicago and Northwest Indiana
http://www.cwcvideo.com
http://www.videopronow.com
http://www.chicagoland-videographer.com -
John Rofrano
November 12, 2011 at 2:30 am[David Wilson] “how can a sony product keep having so much trouble with their own video format?”
More than likely something on your PC is causing it not to work. I have never had any problems with the Sony AVC render type but I keep a clean PC. No codec-paks and nothing that’s not needed. Something on your PC may be interfering. Try and figure out what it is that you do different from when it shows up to when it doesn’t.
~jr
David Wilson
November 12, 2011 at 7:12 amHey John,
Thanks for the quick reply, unfortunately, the only thing I have changed is going from SVP10 to SVP11. The sony AVC codec never disappeared in SVP10. Although, I would have crashes occasionally, but these seemed to be CPU overheating, now have the Antec Kuhler which took care of that. I did just order a new video card (asus radeon 6870)hopefully that will help as well, but after I finish this current project I’m going to try a fresh install unless you have any other ideas.It seems that there are other people in the same boat as me. One thing I have noticed with svp10 and 11 is that Uniblue registry cleaner sees Vegas as a problem and removed it from the registry. But I had problems before using the registry cleaner. In my current project, I still cant find the AVC codec no matter what I do. It really sucks because the MainConcept takes forever to render.David M. Wilson, SCVU
John Rofrano
November 13, 2011 at 2:53 pm[David Wilson] “after I finish this current project I’m going to try a fresh install unless you have any other ideas.”
A fresh install is always a good idea when crazy things like this happen.
[David Wilson] ” One thing I have noticed with svp10 and 11 is that Uniblue registry cleaner sees Vegas as a problem and removed it from the registry. But I had problems before using the registry cleaner.”
I would never, ever, ever, use a registry cleaner. They have no idea what is good and what isn’t. This is probably adding to the problem. I would stop using it.
~jr
Gilles Gagnon
November 14, 2011 at 3:26 pmWith svp11, i’m having the same problem here. i can’t render using the Main Concept template. getting error
“The reason for the error cannot be determined”
It was working well in svp9.
Is there a solution to this?
Cheers,
Gilles
