Activity Forums VEGAS Pro Sony Vegas 11, combining 1920x1080p and HDV1080i
  • Sony Vegas 11, combining 1920x1080p and HDV1080i
    Posted by Jacob Newburn on September 17, 2013 at 11:11 am
    Hello All.
    My project uses footage from two different cameras.
    1:
    General
    Complete name : G:builderberg 2013bilderberg fringe festival 2013HVR (1)�0_0005_2013-06-08_172022.M2T
    Format : MPEG-TS
    Commercial name : HDV 1080i
    File size : 3.97 GiB
    Duration : 21mn 43s
    Start time : UTC 2013-06-08 17:20:22
    End time : UTC 2013-06-08 17:41:56
    Overall bit rate mode : Variable
    Overall bit rate : 26.1 Mbps
    Maximum Overall bit rate : 33.0 Mbps
    Encoded date : UTC 2013-06-08 17:20:22
    Video
    Menu ID : 100 (0x64)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Codec ID : 2
    Duration : 21mn 43s
    Bit rate : 24.5 Mbps
    Maximum bit rate : 25.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.629
    Stream size : 3.71 GiB (94%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 21mn 43s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Delay relative to video : -216ms
    Stream size : 59.7 MiB (1%)
    2:
    General
    Complete name : G:builderberg 2013bilderberg fringe festival 2013100CANONMVI_7727.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 3.42 GiB
    Duration : 10mn 54s
    Overall bit rate : 44.8 Mbps
    Encoded date : UTC 2013-06-08 17:51:51
    Tagged date : UTC 2013-06-08 17:51:51
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L5.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=12
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 10mn 54s
    Bit rate : 43.3 Mbps
    Width : 1 920 pixels
    Original height : 1 088 pixels
    Original display aspect ratio : 16:9
    Frame rate mode : Constant
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.835
    Stream size : 3.30 GiB (97%)
    Language : English
    Matrix coefficients : BT.601
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 10mn 54s
    Bit rate : 1 536 Kbps
    Channel positions : Front: L R
    Bit depth : 16 bits
    Stream size : 120 MiB (3%)
    Language : English
    The majority of the project is using camera 1.
    I am a “Noob” and It would be really nice if we go through this problem step by step.
    Question 1:
    How do i accurately crop camera 2 to the correct size?
    If anyone has seen this question answered elsewhere please post a link.
    Thanks if anyone can help. J.
    John Rofrano replied 12 years, 11 months ago 3 Members · 9 Replies
  • 9 Replies
  • Brad Leigh
    September 17, 2013 at 5:26 pm
    I mix 1920 and 1080 footage all the time in vegas. They are the same aspect ratio. No need to crop
    brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
  • Brad Leigh
    September 18, 2013 at 5:37 am
    Should have said 1920 and 1440.
    b
  • John Rofrano
    September 18, 2013 at 12:18 pm
    As Brad said, 1920×1080 PAR 1.0 is the same size and aspect as 1440×1080 PAR 1.3333. If you multiply 1440 by 1.3333 you get 1920! No worries. Set your project properties up for 1920×1080 and everything will be fine.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jacob Newburn
    September 18, 2013 at 4:24 pm
    Thanks Brad & John!
    Question 2:
    For maximum quality, for the given files, what settings would i use for properties and rendering? (rendering to .MP4)
    Brad, maybe you could post some screen-shots of your settings?
    This forum is my temple of wisdom.
    J.
  • John Rofrano
    September 19, 2013 at 11:44 am
    [jacob newburn] “For maximum quality, for the given files, what settings would i use for properties and rendering? (rendering to .MP4)”
    For Vegas Pro 12.0 use MainConcept AVC with the HD Internet 1080-25p template. That will produce high quality MP4 files.
    ~jr
  • Jacob Newburn
    September 20, 2013 at 2:13 pm
    Thanks John.
    So, for rendering if i use Vegas 12 and start with the “MainConcept AVC with the HD Internet 1080-25p template”, what changes should i make for my files?
    And what settings would use for the Properties?
    Nice One, J.
  • John Rofrano
    September 21, 2013 at 11:28 am
    [jacob newburn] “So, for rendering if i use Vegas 12 and start with the “MainConcept AVC with the HD Internet 1080-25p template”, what changes should i make for my files?”
    None. Why would you make changes? That’s the template that the Sony developers have created for Internet HD delivery.
    [jacob newburn] “And what settings would use for the Properties?”
    Project properties? I would use HD 1080-50i (1920×1080, 25.000 fps).
    ~jr
  • Jacob Newburn
    September 21, 2013 at 1:43 pm
    Thank You John!
  • John Rofrano
    September 21, 2013 at 3:56 pm
    You’re welcome Jacob.
    ~jr
