Activity › Forums › VEGAS Pro › Sony Vegas 10 Pro
  • Sony Vegas 10 Pro
    Posted by Jason Jameston on April 27, 2011 at 5:44 pm
    Okay so I have read lots of Forums and other problems people have had for the past 3 days or so trying to fix this. Whenever I try and drag a video file into the timeline Vegas will crash on me. Here is the error code:
    Application Name: Vegas Pro
    Application Version: Version 10.0a (Build 387)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.5570_none_509463cabcb6ef2a\MSVCR90.dll
    Fault Address: 0x709E4682
    Fault Offset: 0x00024682
    I looked around the forums and basically the error code specifically is a general access violation but everyone’s situation for this code appearing seems to be different at least to mine so I figured I would post this in the hopes that someone can help. I have just tried importing audio and pictures to the timeline and those work perfectly which makes me think this is a solvable problem. The file type is .M2TS recorded off of a Hauppauge PVR. Recorded is PS3 gameplay footage with the settings that this guy uses:
    https://www.youtube.com/watch?v=UYzWrAUGg4Q
    The oddest part is that I can edit and move around video files of the same exact type that were created before I tried upgrading to Pro 10.00c. I tried the upgrade and then when I restarted the computer nothing happened when I would try to open the program. So I uninstalled it and reinstalled it and now I get that error message when importing media that was not part of a project before the attempted update. I can also create a new project and drag a media file in an older project into it and it works fine if that helps any.
    Thank you very much to anyone willing to help, I know this is a lot of information, I just wanted to get it all out there from the get-go.
    Jeff Schroeder replied 15 years, 5 months ago 4 Members · 13 Replies
  • 13 Replies
  • John Rofrano
    April 27, 2011 at 8:33 pm
    [Jason Jameston] “The file type is .M2TS recorded off of a Hauppauge PVR.”
    Vegas works best with the AVCHD setting on the Hauppauge PVR. I use this all the time with Vegas Pro 10c without any problems.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jason Jameston
    April 27, 2011 at 8:40 pm
    But see I’ve been using the .M2TS file type for every single video so it’s not like I suddenly changed anything. And as I stated previously, I tried to upgrade to 10.00c but it didn’t work so I had to reinstall 10.00a. One of my friends suggested it might be a codec problem. Is that a possibility?
  • Jeff Schroeder
    April 27, 2011 at 10:32 pm
    Jason,
    Your faulting modules was from the runtime lib for visual c++ ver. 9.
    I am pretty sure this is integrated with .net 3, you may want to check around on the web about that.
    You might want to try uninstalling MS VC 9 and re-install that latest redistributable.
    Jeff
    http://www.narrowroadmedia.com
  • Jason Jameston
    April 27, 2011 at 11:13 pm
    Just to be clear, you are referring to Microsoft Visual C 9 right? Sorry, I’m still quite new with some of the more technical parts of editing.
  • Jeff Schroeder
    April 27, 2011 at 11:30 pm
  • Nigel O’neill
    April 28, 2011 at 1:15 am
    Vegas should install what VC++ redistributable runtime modules it needs during installation.
    Jason, I am a little confused:
    Were you able to install 10c?
    I am even more confused in that your error message relates to 10a. Do you have an error message relating to 10c?
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Jason Jameston
    April 28, 2011 at 1:29 am
    I was not able to successfully install 10.00c. It went through with the installation, told me to restart my computer and I did this. Then once it was restarted I tried to open Vegas but it would simply show the “loading”… circle thing next to my mouse for a second or so and then nothing would happen. I looked in the processes tray and it was not running. So, I uninstalled it and reinstalled the set-up I had which was for 10.00a. So yes, I have Vegas Pro 10.00a.
    I just tried installing MC VC 2010 redistributable and it did not work. Should I uninstall MC VC 9 first?
  • Jason Jameston
    April 28, 2011 at 2:08 am
    Wow, so for some reason really weird things are happening.
    1st: All of the files that I have recorded previously are apparently AVCHD (even though I recorded them on the setting of Playstation 3 in Hauppauge which is supposed to be .M2TS).
    2nd: As a test, I tried recording footage in AVCHD format and it imported perfectly with no errors or anything.
    So, I still have a few hours of footage that I would like to use but as stated before Vegas will crash whenever I try to bring it into the timeline. The only option I see is converting the file type. Does anyone know of a file converter that does not lower the quality of the original file?
    P.S. I am going to try using the conversion tool included in TotalMedia Extreme (software included with the Hauppauge)
  • Jason Jameston
    April 28, 2011 at 3:33 am
    So I found out something. The files that would crash Vegas whenever I dragged them to the timeline were recorded at a lower bit rate. The files that work are in 13.5Mbps and the ones that don’t are around 9.4Mbps. I don’t know why that would give this kind of an error but it does.
  • John Rofrano
    April 28, 2011 at 12:06 pm
    [Jason Jameston] “2nd: As a test, I tried recording footage in AVCHD format and it imported perfectly with no errors or anything.”
    This is why I recommended it. This is the best format to use with Vegas from the HD PVR device.
    ~jr
