SONY VEGAS 10 aviplug dll crash
Posted by Jean Carlo on January 18, 2012 at 3:28 amGuys,
please help me ! I am so frustrated with sony vegas, It keeps crashing all the time . It shows I have probelm with cineform, I guess,
file Io/aviplug.dll. I tried everything you can imagine but the problem dont go away. I have a nice computer windows 7 64 bits a decent graphic card Nvidia GTX 560, cineform neon.
I usually convert files from my canon hv20 to 24p. Vegas keeps crashing all the time.The project is pretty big. Also, most of my files are in a external drive, when I am editing on the timeline it makes some crazy noises as the frames start to show up, that’s when it
crashes. Sometimes when vesgas starts it crash showing the same information aviplu.dll
Guys I need your help, I don’t know what to do at this point.
thanks
jeanJean Carlo replied 14 years, 8 months ago 4 Members · 10 Replies -
Steven Talley
January 18, 2012 at 3:32 pmTry replacing the aviplug.dll with this one from an earlier thread,
https://f1.creativecow.net/1447/32bit-aviplugdll-to-fix-problem
To keep the original file but not load it just rename it to aviplug.dl1 or something similar before dropping the new aviplug.dll into the plugin folder. Do a search for the file name to find where the replacement file needs to go. -
Steve Rhoden
January 18, 2012 at 9:02 pmAlso Cineform is a contributor to your crashes. Possibly working on
footages in the Cineform format.Steve Rhoden
(Cow Leader)
Film Maker
Filmex Creative Media.
1-876-832-4956
https://filmex-creative-media.blogspot.com/ -
Jean Carlo
January 19, 2012 at 2:26 amhey Steve, thanks for your input. If Cineform is the problem, is there any solution ? any update ?
Jean Carlo
January 19, 2012 at 2:28 amHey Steve thanks for the input. Should I keep the same aviplug.dll in the same fold ? thnaks
Steven Talley
January 20, 2012 at 2:07 amAs long as the original is named using .dl? and not an L, Vegas will not see it and try to load it.
Angelo Mike
January 20, 2012 at 4:20 amI tried this solution when Cineform avi files were giving me major problems in Vegas, and it didn’t work. I even emailed the guy who created this solution and he couldn’t help me.
Cineform avi has become a nightmare to work with in Vegas, at least for me. I’ve started editing footage straight from my cameras as AVCHD. It’s compressed, with lower chroma subsampling, and the compression means that previewing and editing can cause slowdown, but the improvement is massive.
I would suggest using the footage straight from your camera, which I’m pretty sure is mpeg. I used to edit footage on a Vixia HV30, and would use Cineform to turn it into 24 fps footage.
I used to just render the footage out to 30 fps progressive scan and interpolate or blend the interlaced fields. Make sure your project properties match your footage, and when you render out, I would think you can render to 24 fps progressive scan and blend or interpolate the footage. Or, right click the clips, click Properties, then “disable resample” to make Vegas pull the extra frames out. That might not work on the kind of footage you shot, so I’d do some tests on both in your most movement filled footage to make sure there’s no ghosting of frames.
Basically, stop using Cineform avi.
http://www.scenethroughglass.com
Jean Carlo
January 21, 2012 at 1:11 amHey Angelo Thanks for your input.
I’m so desperate ! I’m convinced that Cineform is the problem, however,I have over 50 hrs of my project converted to avi. At this point I have no plan B, I got have it edited. I was trying to find a way to downgrade from sony vegas 10 to vegas 9, can’t find a way to do that, in fact, I don’t think it is possible. It seems that cineform is sony vegas 9 friendly. I was also thinking of switching to adobe premiere cs5, not sure if i will have the same problem with cineform and Adobe. I am really upset with this situation becouse I have many hours already edited and cannot give up now. This Cineform is a complete night mare !!! I am considering start my project from the beginning all over again but I got be sure that since my files are under cineform conversion I don’t want to play this game again and don’t win . If you have any idea please help me man ! -
Angelo Mike
January 21, 2012 at 3:08 pmIn my experience, no, absolutely not. I would download mpeg streamclip, which is a free and easy to use program, and use it to convert your avi footage into mpeg. Open your project, and when Vegas asks you to replace missing files, just pick the ones you replaced, and you should be able to complete your project.
Jean Carlo
January 21, 2012 at 4:03 pmThanks Angelo, my concerning is about the quality loss, at this point I don’t think that’s the case.
