Activity Forums Sony Cameras Sony Unveils New HXR-NX5U Solid State Camcorders
  • Sony Unveils New HXR-NX5U Solid State Camcorders
    Posted by Creative Cow on January 12, 2010 at 12:29 pm
    (Park Ridge, New Jersey–January 12, 2010) Sony Electronics is expanding its line of solid state camcorders, introducing its first professional camcorder that implements the AVCHD format, the HXR-NX5U.
    The professional HXR-NX5U model is part of Sony’s NXCAM family of video products for professionals. It features Sony’s Exmor™ CMOS sensor with ClearVid™ array, to deliver full high-definition resolution and low light sensitivity with low noise. The camcorder will record AVCHD up to 24Mbps, delivering 1920×1080 high definition images with both interlace and progressive modes along with native 1080/24P, 720/60p and MPEG-2 standard definition recording.
    Sony has also introduced a “prosumer” camcorder, the HDR-AX2000 Handycam® camcorder. However, there are key distinctions between each model. Only the professional NX5U camcorder includes both HD-SDI and HDMI™ outputs, as well as two-channel linear PCM audio capabilities. Other unique features for the professional NX5U camcorder include 720/60P recording, built-in GPS function, SMPTE Time Code I/O and an upgrade option for 60i/50i switchable.
    AVCHD technology has been widely adopted in Sony’s consumer camcorder line. In the professional market, Sony has already introduced one AVCHD-based model: the compact point-of-view (POV) camera and solid-state recorder combination, model HXR-MC1.
    According to Sony, AVCHD is a highly efficient long-GOP codec based on MPEG-4 AVC/H.264 Long-GOP image compression, a member of the MPEG family of codecs. This approach is consistent with Sony’s current line-up of MPEG professional camcorders, including the HDV™, XDCAM® HD optical and XDCAM EX™ series.
    The new NXCAM model also shares the 20x optical zoom G lens used in Sony’s HVR-Z5U professional camcorder. The camcorder uses two types of consumer media along with an optional HXR-FMU128 128GB Flash Memory Unit for more than 11 hours of recording time at 24 Mbps. The HXR-FMU128 unit can be easily removed and simply powered through a computer’s USB connection, to make file downloading or editing easier and faster. Besides the Memory Stick PRO Duo™ media, users are also able to record HD content on class 4 or higher SDHC cards. Sony is also expanding its industry leading line of consumer media with the addition of five new SD/SDHC memory cards for digital imaging products, including camcorders.
    The new HXR-NX5U will be available this month, at a suggested list price of $4,950, which is the same as Sony’s highly successful HVR-Z5U. The HXR-FMU128 unit will also be available this month, at a suggested list price of $800. It can only be used with the professional model HXR-NX5U, not with the HDR-AX2000.
    Creative Cow replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
