Activity › Forums › Sony Cameras › sony PMW-Ex1 w/ FCP – error message “Pro codecs required”
  • sony PMW-Ex1 w/ FCP – error message “Pro codecs required”
    Posted by Lisa Rolley on May 7, 2008 at 7:48 pm
    I have yet to hook the actual camera up but I am trying to make sure I have everything ready to go – latest version of FCP on an 8 core and just downloaded the required software from the Sony site.
    When i go to Import and select xdcam from the import menu it gives me this error message.
    Is this because i dont even have the camera connect to the mac or am i indeed actually missing some codecs – if so where do i get these?
    thank you
    Lisa
    Don Greening replied 18 years, 4 months ago 2 Members · 1 Reply
  • Don Greening
    May 7, 2008 at 8:17 pm
    I just tried choosing “Import Sony XDCAM” from the file menu without having my EX1 connected and the Sony Transfer Tool started up within FCP and I got this prompt in the main Transfer Tool window:
    “Use the Add button or insert media into a connected XDCAM device”
    I got no warning about not having the correct codecs installed, so I don’t know why you’re getting that warning on your machine. The XDCAM codecs reside within FCP and not with the Sony Transfer Software. Just double-check that you have the following bits to make it all work:
    FCP v. 6.0.2 or better
    Mac OS 10.4.11 or better
    Quicktime v.7.3.1 or better
    Sony Transfer Tool v.2.1 or better
    Sony FAM driver
    – Don
