Activity › Forums › Sony Cameras › Sony PMW-EX1 Firmware Update1.26 is this result normal.
  • Sony PMW-EX1 Firmware Update1.26 is this result normal.
    Posted by Daniel Goyette on June 12, 2011 at 11:40 pm
    I everybody i have in the past update the firmware on my PMW-EX1 from 1.11 to 1.20 and now 1.26.
    Everything fine exept when i go to language selection i see :English , Japaneese , Chineese , is this normal.
    I got the firmware from Sony UK since i could not find-it (V1.26) on Sony Canada or Sony USA for the EX1.
    Even if my primary language is French i keep all my NLE in English for simplicity and keyboard configuration.
    Very happy English is there but was expecting French and Spanish , info to install was in about 6 languages.
    Is the Sony download source or country made any difference on languages included in the firmware.
    If it become available in Canada or USA should i download-it and apply-it , will it work if it still 1.26.
    Should i forget all this and wait for a next firmware update or it is the standard international languages version.
    PRODUCTION D. GOYETTE
    TOURNAGE / MONTAGE VIDÉO CORPORATIF
    DISTRIBUTION DVD / BLU-RAY / H.264
    https://web.mac.com/edbeta
    Duncan Craig replied 11 years, 5 months ago 5 Members · 5 Replies
  • David Gallessich
    June 16, 2011 at 8:27 pm
    Daniel – I would check Ian’s response in this thread:
    https://forums.creativecow.net/readpost/142/876092
    And in your case, I would probably call that phone number in my post.
    (When phone menu starts getting specific, select menu item 4.)
    In my case, the wait-time was reasonable and the tech was pretty helpful.
    They may know what you should do if you already installed 1.26 using a bad installer.
  • Daniel Goyette
    June 17, 2011 at 6:59 pm
    I call the number an follow your instruction about selecting item 4 in the Sony phone menu system.
    I got very kind an fast information about my downloaded and installed firmware on my PMW-EX1.
    It is normal to see English , Chineese , Japaneese languages selection , so all is fine an i can relax.
    Thank-you and thank-you also to Ian Cook who should post about this.
  • Ian Cook
    June 17, 2011 at 8:51 pm
    Hi Daniel-
    That is correct. The language selection is normal for a US or European model.
    Cheers,
    Ian
  • Pushpanatha De silva
    July 2, 2011 at 10:27 am
    Hi Ian and all
    My present f/ware version is 1.11 and would like to upgrade upto 1.26. So do I have to upgrade to 1.20 before I upgrade to 1.26 or I can upgrade straight away to 1.26 from 1.11.
    Your help is much appreciated. Thanks
    Pushpa
    Australia
    Dell Workstation T7500
    Dell HD Monitors
    Sony PMW EX1
  • Duncan Craig
    April 14, 2015 at 4:55 pm
    It’s an old thread I know, I know!
    I normally stick to trusty 16GB cards, but recently tried some 32GB UHS1 SDHC class cards in my EX1 and got formatting errors.
    I spoke to Sony and went to the following page: https://www.sony.co.uk/pro/product/broadcast-products-camcorders-xdcam/pmw-ex1/support/
    I was on v1.11 firmware from way back when I bought the trusty EX1. Anyway, the latest 1.3 binary on there includes a nice Mac app which seemed to perform the update to 1.3 in two stages.
    Once updated the app asks to be exited. At that point I was stuck. I remove the USB cable and disconnect the power supply. I then plugged the power in again and it rebooted first time.
    All working well now with a couple of different 32GB cards in the camera.
    FS100, EX1, GoPro, 2x Hacks, FCPX etc
