Sony PMW-EX1 Expanded Focus – Can it be set to stay on indefinitely?
The Expanded Focus button on the EX1 is quite handy for getting the focus right on the camera. But when you are shooting with a lens adapter such as the Red Rock or the Letus Extreme, the Expanded Focus button does not realize you are setting the focus on the attached lens rather that the EX1. It will shut off the expanded focus midway between your attempt to focus!
Does anyone know if there is a setting or a way to keep the Expanded Focus on until you press the button again to turn it off?
