Activity Forums Sony Cameras Sony PMW-200 file import into Premiere Pro CS6 only get 1 Ch. audio
  • Sony PMW-200 file import into Premiere Pro CS6 only get 1 Ch. audio
    Posted by Frank Wu on May 5, 2013 at 3:25 am
    Just bought Sony PMW-200 and did some test shoot with the 4 channels audio. But when I imported the files into Premiere Pro CS6, only one Channel (Ch.1) shows on one audio track. Whatever I changed the preference and setting, can only find 1 Ch.
    And I tested the files on my friend’s computer, who uses Sony Vegas Pro 12, all 4 channels show up on 4 tracks.
    Can anyone tell me what should I do in order to work with all 4 audio channels in Premiere Pro, cause I don’t use Vegas.
    Frank Wu replied 13 years, 4 months ago 2 Members · 2 Replies
  • Ian Cook
    May 6, 2013 at 2:25 pm
    I’m guessing since you said ‘4 channels’ that you are working in FAT (EX/.mp4) mode? I don’t see this on any of my systems here. What format/frame rate are you using and when you import is it via the Media Browser or File–>Import?
  • Frank Wu
    May 6, 2013 at 5:44 pm
    My bad, I only copied the video files (EX/MP4) to my hard drive, and imported them in to Premiere Pro CS6, only got Ch. 1 of the audio.
    Now I tried to copy the whole BPAV folder to my hard drive in a new named folder, and import this new folder into Premiere Pro CS6… now I got 4 Ch. audio.
    Also it’s easy to browser and Ingest the folder in Adobe Prelude CS6.
    Thanks for helping!
