Activity › Forums › VEGAS Pro › Sony MXF or XDCAM EX : What’s the best intermediate format for HandBrake ?
  • Sony MXF or XDCAM EX : What’s the best intermediate format for HandBrake ?
    Posted by Cedric Divang on May 28, 2014 at 6:09 pm
    Hello,
    I’m using Sony Vegas to edit the vidéos and HandBrake to render them so I need an intermediate format.
    Sony MXF (.mxf) and XDCAM EX (.mp4) are very interesting because they don’t need recompression when there are no transitions/effects applied to the video so they are very fast to render. And both are compatible with Handbrake.
    But to my eye, these formats look exactly the same. Is there a drawback in using one rather than the other ?
    Thanks for your help 🙂
    ____________________________________________________________
    Here are my render parameters (they fit the source video) :
    Video Format : HD
    Frame Size : 1440×1080
    Frame Rate : 25.000
    Aspect Ratio : 16:9
    Field Order : Upper Field First
    Prioritize Quality Over Speed : YES
    Video Quality : 31 (MAX)
    Bit Rate : 25 (CBR) – SP
    Profile : Main
    Jane Kong replied 11 years, 9 months ago 5 Members · 13 Replies
  • 13 Replies
  • Norman Black
    May 29, 2014 at 4:44 am
    Sony MXF HD and HD EX is the same as XDCAM EX, in the 25 CBR and 35 VBR formats.
    Sony MXF will output your audio in two mono channels instead of a single stereo channel. Handbrake does not handle the two mono channels. XDCAM EX outputs a stereo audio channel and would be a better choice for Handbrake due to this issue.
  • Cedric Divang
    May 29, 2014 at 8:46 am
    Thank you ! 🙂
  • Mike Kujbida
    May 29, 2014 at 12:49 pm
    Norman, I’m not sure why you get two mono channels as I render to MXF a lot and always get a single stereo channel.
  • Norman Black
    May 29, 2014 at 3:08 pm
    Every time I have rendered Sony MXF HD EX I get two audio channels as described in the Audio tab. One for each channel (left, right). I verify this with MediaInfo. I also see this with XAVC MXF files. The audio tab does not give an option for a single Stereo audio channel.
    XDCAM EX MP4 however does give an option for a single Stereo audio channel in the file.
    I would be interested in how to get a Stereo audio channel out of MXF files. Specifically XAVC, as I would like to use that as an intermediate to Handbrake. Handbrake is not smart enough to treat the two separate channels in the file as a stereo channel.
  • Mike Kujbida
    May 29, 2014 at 7:05 pm
    Not sure what to tell you Norman. I just tried it in Pro 10 and 12 and everything I did gave me a single stereo audio track. Just for fun I did a test with a stereo audio track and two mono tracks, one panned hard left and the other hard right. Once again, my render was a single stereo audio track.
  • Norman Black
    May 29, 2014 at 7:37 pm
    I have only ever used VP12 and VP13 and both have operated the same for me with MXF file output. Sony MXF HD EX or XAVC Intra.
    Here is what I have from the Sony MXF template. The Audio tab.
    Here is my MediaInfo dump of a resulting render as.
    General
    Complete name : D:\Renders\BabyBearDrop.mxf
    Format : MXF
    Commercial name : XDCAM HD 35
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 40.5 MiB
    Duration : 11s 712ms
    Overall bit rate mode : Variable
    Overall bit rate : 29.0 Mbps
    Encoded date : 2014-05-29 19:31:43.000
    Writing application : SONY Vegas 13.0.0.310
    Writing library : SONY Vegas 13.0.0.310
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format_Settings_Wrapping : Frame
    Codec ID : 0D01030102046001-0401020201030300
    Bit rate mode : Variable
    Bit rate : 35.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.563
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 48.9 MiB
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format_Settings_Wrapping : Frame (AES)
    Codec ID : 0D01030102060300
    Bit rate mode : Constant
    Bit rate : 768 Kbps
    Channel(s) : 1 channel
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 1.07 MiB (3%)
    Audio #2
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 00:00:00;00
    Time code settings : Striped
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
  • Cedric Divang
    May 30, 2014 at 1:15 am
    Same here Norman ! When I convert to .mxf, Stereo sound turns into Mono !
    And not only in Handbrake but also in VLC.
    @Mike : Just download this small Stereo file https://www15.zippyshare.com/v/38446323/file.html and render it with “Sony MXF (*.mxf) > HD 1440×1080-50i” on Sony Vegas Pro 13. Play the rendered video with VLC and you’ll see that the sound becomes mono (same if you attempt to render it with handbrake). Now render the source file with any “XDCAM EX (*.MP4)” template and the stereo will remain.
    If you don’t get the same result as Norman and me, then you are probably using a different Version of Vegas.
    Thanks again to Norman for his help, I had never noticed that *.mxf files had problems with stereo.
  • Norman Black
    May 30, 2014 at 1:48 am
    I don’t get “mono” audio. The audio is still stereo, it is just that the left and right channels are output separately in the MXF file. Some, but not all video players can deal with this. Most NLE’s will probably get it right.
  • Mike Kujbida
    May 30, 2014 at 1:45 pm
    Norman, my audio tab for Pro 10 and 12 looks identical to yours.
    To both of you, do you have the Import stereo as dual mono option enabled in Options > Prefs > General?
    I rendered out the test file that Cedric uploaded and still get the same result, a single stereo file.
    Here’s a screenshot of my timeline with the original file and the ones rendered in Pro 10 and Pro 12.
    Here are the MediaInfo reports for Pro 10 and Pro 12.
    Pro 10 report
    General
    Complete name : E:\VegasTemp\test-10.mxf
    Format : MXF
    File size : 26.7 MiB
    Duration : 36s 603ms
    Overall bit rate : 6 116 Kbps
    Encoded date : 2014-05-30 12:59:58.000
    Writing application : SONY Vegas 10.0
    Writing library : SONY Vegas 10.0
    Video
    Format : MPEG Video
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Stream size : 153 MiB
    Audio #1
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Stream size : 3.35 MiB (13%)
    Audio #2
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    Pro 12 report
    General
    Complete name : E:\VegasTemp\test-12.mxf
    Format : MXF
    Encoded date : 2014-05-30 13:07:11.000
    Writing application : SONY Vegas 12.0.0.770
    Writing library : SONY Vegas 12.0.0.770
    Video
    Format : MPEG Video
    Color space : YUV
    Bit depth : 8 bits
    Audio #1
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Audio #2
    Format : PCM
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
  • Norman Black
    May 30, 2014 at 2:53 pm
    [Mike Kujbida] “Norman, my audio tab for Pro 10 and 12 looks identical to yours.
    To both of you, do you have the Import stereo as dual mono option enabled in Options > Prefs > General?”
    No my prefs for Import MXF as multi-channel and Import stereo as dual mono are both unchecked.
    Your MediaInfo dumps show that you also get separate audio channels in the MXF file for the left and right stereo channels.
    Of course Vegas is able to import the dual channels as a stereo channel. Most NLE’s are probably able to handle this.
    Cedric mentioned using intermediates to Handbrake, and my original post stated that MXF gets two audio channels for stereo and that Handbrake cannot handle two separate channels and treat it as stereo. As Cedric pointed out, some video players also cannot handle this Vegas MXF file (MXF in general?) audio behavior.
