Activity › Forums › Apple Final Cut Pro › Sony MRC1K to FCPX workaround
  • Gerry Fraiberg
    November 19, 2011 at 3:53 pm
    If the plugin doesn’t work, perhaps the easy solution would be to continue to use FCP 7 to ingest the files, then import from the hard drive location. I have a Z5U, and use FCP 7 to Log & Capture HDV tape. The files import nicely, although you don’t get all data such as Reel Name.
