Sony miniDV deck and Final Cut Pro 6
I work at a university and they purchased quite a few Sony GV-D1000 decks for labs last year. With the recent install of Final Cut 6 the “Print to Video” function has had intermittent problems. I have yet to see the problem myself, but apparently the miniDV tapes occasionally have gray blocks on them when students print to tape. We can’t get the problem to happen all the time, like I said it was intermittent.
One of my friends did a great deal of research on the problem and the “gray blocks” are the exact symptom that is described when a deck is communicating as PAL and FCP is communicating as NTSC. (Sorry if this sounds a bit confusing, I am trying to remember the info that I received third person.) He called Apple and they said that they could not help him because they do not support that particular deck, and they gave him a web address of supported decks.
Thus, not supporting the deck is probably a hint that I shouldn’t pursue a solution, however, I was wondering if anyone else is using FCP 6 and this deck. It seems to happen on the Intel Macs, but the G5’s in edit suites are not having this problem.
Any ideas?
