Activity › Forums › Apple Final Cut Pro Legacy › Sony m25 deck????
  • Sony m25 deck????
    Posted by Delano Bryant on October 10, 2007 at 4:40 pm
    Does anyone know what we can use to capture Canon XL H1 footage? 1080i 30p cpatured on XL H1. The SOny decks won’t play the footage. I keep getting change format error.
    Is that the color red you want to use?
    Bill Lee replied 18 years, 11 months ago 5 Members · 6 Replies
  • Walter Biscardi
    October 10, 2007 at 5:03 pm
    My understanding is you must use the Canon cameras to capture their HDV footage. It’s somewhat proprietary HDV codec.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Shane Ross
    October 10, 2007 at 5:07 pm
    Canon CLAIMS that their form of HDV is the same as Sony’s and that you SHOULD be able to use the Sony decks to capture CANON footage.
    I have yet to hear of someone doing that successfully.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Chris Borjis
    October 10, 2007 at 5:08 pm
    [hdfilmmaker] “I keep getting change format error.”
    That means someone has switched the output to SD/DV.
    Go into the menu and change it to HDV or AUTO.
    The Sony HDV Decks can play Canon HDV tapes perfectly, except for 24F tapes, those can only be played by Canon HDV Camcorders.
  • Delano Bryant
    October 10, 2007 at 5:21 pm
    I’ve changed the settings on the deck to HDV auto. and I still get the same errors.
  • Chris Borjis
    October 11, 2007 at 2:35 am
    ok try just HDV. (auto usually works)
    If it still can’t play then it must be a 24f recording.
    I capture Canon HDV often on that deck and it works.
  • Bill Lee
    October 12, 2007 at 1:26 am
    I get a whole lot more reliable captures when the deck is switched to the appropriate format (DV or HDV) explicity, rather than relying on AUTO. Apple even suggests that you do so: https://docs.info.apple.com/article.html?artnum=302407
    If people are reusing tapes and/or have mixed DV and HDV encoded material, then FCP doesn’t deal well with the format changing while playing back or during capture.
    Bill Lee
