Activity Forums Apple Final Cut Pro Legacy Sony LMD monitor in dvi
  • Sony LMD monitor in dvi
    Posted by Robin Plomp on June 5, 2009 at 12:46 pm
    Hi there,
    Trying to setup a FCP system. Is it posible to connect our LMD-2450 to the second dvi output of the MacPro and view the fullscreen video signal in HD on this device?
    Kind regards,
    Pro Motion Pictures
    Robin Plomp
    John Fishback replied 16 years, 11 months ago 2 Members · 1 Reply
  • John Fishback
    June 5, 2009 at 10:25 pm
    You need and I/O card or box. For viewing only a MXO would work. https://www.matrox.com/video/en/products/mxo/
    A Kona card or box (there are many choices) would allow you to both view and output as well as capture from tape or other sources. https://www.aja.com/products/kona/ There’s also a MXO 2 which gives you in and out.
    If you simply hooked your monitor to the second DVI output what you’d see is more desktop. It would not allow you to see high-quality HD as you would with one of the other solutions.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
