Activity Forums AJA Video Systems Sony JH3 capture issues
  • Sony JH3 capture issues
    Posted by Matt Gottshalk on August 14, 2008 at 2:03 pm
    Hi All,
    Trying to capture a timeline form a Sony JH-3 Deck.
    My system:
    Octocore mac 3.0ghz
    16gb ram
    Kona 3 card
    MaxxDigital 8TB Esata Raid (Raid 5)
    Client’s Sony JH-3 deck
    Issues:
    I can get video when I capture (at Kona 8bit 1080i 29.97), but no audio.
    Also, if I try to capture prores HQ or Kona 10 bit uncompressed it drops frames.
    Any ideas?
    703.615.8614
    Any ideas?
    McGee Digital Media Inc.
    24P HD Production and Post
    https://www.mcgeedigitalmedia.com
    Matt Gottshalk replied 18 years ago 5 Members · 8 Replies
  • 8 Replies
  • Gary Adcock
    August 14, 2008 at 2:26 pm
    [Matt Gottshalk] “I can get video when I capture (at Kona 8bit 1080i 29.97), but no audio. “
    is the Kona control panel set to input embedded audio? AES is the default.
    [Matt Gottshalk] “Also, if I try to capture prores HQ or Kona 10 bit uncompressed it drops frames.”
    Ok those could be 2 different things-
    1080 UC footage dropping frames is usually a storage issue -but that array should be fast enough.
    1080 ProRes dropping frames has to do with your configuration. RAM is the #1 culprit- first re-seat all of the chips, making sure that you are only using matched sets. Pull All unmatched chips and all less than 1G and see if you can capture.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Matt Gottshalk
    August 14, 2008 at 3:10 pm
    Thanks Gary I will check that out.
    Enjoyed your presentation on RED work flow at NAB this year!
  • Gary Adcock
    August 14, 2008 at 5:15 pm
    [Matt Gottshalk] “Enjoyed your presentation on RED work flow at NAB this year!”
    Thanks Matt. I will have more next NAB on that too.
    let me know how it goes for you.
    gary adcock
    Studio37
  • Matt Gottshalk
    August 14, 2008 at 5:28 pm
    Well,
    I opened up the mac, ALL ram was 2gb sticks, all from the same manufacturer. Reseated it anyway. Also reseated the Kona 3 card and Esata card.
    No dice on 10 bit, no dice on 8 bit either as FCPro is giving me deck control issues in batch digitizing. I can digitize by capture now.
    I think it is a JH-3 issue.
  • Bob Zelin
    August 15, 2008 at 2:26 am
    Matt –
    I don’t know what generation of MAC you have. the Kona 3 and the SAS/SATA host card must be in x4 slots (or higher) – newer MAC Pros have all x16 slots, but if you have any of these cards in a x1 slot, you will be screwed.
    Right now, go to your AJA Utilities folder, and run AJA System test on the Maxx EVO drive array. Select a 2 Gig file, and select a test size of at least 1080i or 2K (the last 2 choices in AJA System test). Run this test. Are you getting a MINIMUM of 450mb/sec thruput ?
    As for your audio, go to the AJA Control Panel, select the input tab, and select EMBEDDED AUDIO (and not AES/EBU audio).
    Let me know what happens. You should NEVER be getting dropped frames with this configuration.
    Bob Zelin
  • Grant Lovering
    August 15, 2008 at 11:14 pm
    I think Bob is onto it with the card locations. We had the same problem with a blazing system and RAID, SD was capturing but HD was dropping. Turned out the system arrived with the fibre channel card where the AJA card should have been. Swapped them around as per the AJA tech notes and problems solved.
    This should show you what you need.
    https://www.aja.com/html/support_kona_rec_sys.htm
  • Paul Provost
    August 17, 2008 at 6:22 pm
    what frame rate was the tape recorded at? we have seen video with no audio if the JH3 is not set correctly to match (or crossconvert) the tapes rate. (ie 23.98 tape and deck set to 24, etc.)
    Paul Provost
    http://www.postandbeam.tv
  • Matt Gottshalk
    August 17, 2008 at 8:57 pm
    Deck works now.
    Kona input needed to be on EMBEDDED audio vs AES.
    AJA tech support emailed me a plugin to keep FCPro from polling the deck every few seconds.
    Everything is working fine.
    Thanks all.
