Activity › Forums › Apple Final Cut Pro Legacy › Sony HVR Z1P and Final Cut Pro
  • Sony HVR Z1P and Final Cut Pro
    Posted by Thejackles on August 3, 2006 at 2:09 am
    Help! I can’t get FCP to connect to my HVR Z1P camera. I am using a i.Link firewire cable to connect the camera to the computer, and the computer is a Mac G5 with OSX tiger and FCP 5 installed. Any tips???? Is it a FCP setting or perhaps a video card issue? Or a camera setting?
    Mark Maness replied 20 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 3, 2006 at 4:31 am
    Connect the camera via FireWire with it powered down. Then turn it on using the VTR or VCR mode. In the View Menu select Refresh A/V devices. Select the easy setup for HDV that matches what you shot. If this fails, try iMovie, and if that fails, try another FW cable. Sometimes just trashing preferences and restarting the mac with the camera connected and powered up brings it all back too.
    If all the above doesn’t work. You have a hardware or software install problem somewhere. FW ports are touchy and don’t like powered up drives or cameras/decks connected to them NEVER do this.
    There’s a PMU switch you can push on your motherboard too to reset the power management system wide to see if that’s the problem. Must have your computer unplugged from power first though.
    If all of this fails… you might try reinstalling QT 7 using this method: https://docs.info.apple.com/article.html?artnum=301852 and if that doesn’t work… you have a hardware problem most likely… hopefully it’s not the camera’s port… that’s way expensive to fix. The mac you have is a tower or an iMac? If an imac that’s a new motherboard waiting to happen… can’t add a FW card to it like a tower could.
    Jerry
  • Mark Maness
    August 3, 2006 at 2:15 pm
    If this camera is anything like the HVR M10U, then you’ll have to setup thae camera for firewire output. You’ll have to go into you Menu, go down till you see the doulbe lines with arrows on the ends (input/output), set the iLink Conv to “ON” to get the firewire to work. It defaults to off for some weird reason.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
