Activity › Forums › Adobe Premiere Pro › Sony HDV->DV in PPro not working?
Posted by Martin Munthe on September 28, 2005 at 10:35 amAm I the only one having problem with this? I’m trying to capture th HDV stream downconverted to DV from a HC1 through FireWire. I don’t get any feed at all and I can’t control the camera. Works fine with Windows Movie Maker on the same machine. I’m using PPro 1.5.1.
Martin Munthe
DP | Director
https://www.operafilm.com/edit.htmlMartin Munthe replied 20 years, 11 months ago 2 Members · 4 Replies -
Redgum
September 28, 2005 at 1:09 pmI think the problems with the HC1 have been discussed in detail before. Do a search or have a look in the HDV section.
Redgum Television Productions
Broadcast & Corporate Documentaries
Brisbane, Australia -
Martin Munthe
September 28, 2005 at 4:31 pmApart from this thread I don’t get one hit with “HC1” as a search term. In any forum here at the Cow. And this is really a Premiere Pro problem and belongs here since I can capture the downconverted mpeg stream with a simple application like Windows Movie Maker.
Can this be a confusion i Premiere Pro when Cineform is involved? Does Cineform confuse Premiere Pro from knowing if it’s dealing with a DV device or a HDV device? I can capture regular HDV from the camera but the downconversion doesn’t work. The machine I’m working on right now is not really up to specs on editing HDV (I get drop frames – or rather “drop seconds” as we’ll be getting used to editing long GOP’s) so I would like to edit DV.
Martin Munthe
DP | Director
https://www.operafilm.com/edit.html -
Redgum
September 30, 2005 at 9:04 amSorry Martin,
Try this thread over at the Adobe Premiere Pro forum…https://www.adobeforums.com/cgi-bin/webx?13@1019.UBh1ebAO7Wf.4@.3bbc09f4/15
Might help.
Martin Munthe
October 2, 2005 at 6:05 pmWell. The thing is I don’t have any problems capturing HDV. I’m having trouble capturing DV. I can’t use the HC1 as a regular DV source (with it’s VCR HDV->DV internal setting). I’ve checked the camera with EDIUS, Vegas, Windows Movie maker and Avid. All of them can handle the HC1 as a DV device. Premiere Pro can only handle the HC1 as a HDV device using the Cineform driver. It can’t handle it as a standard Sony DV device.
Martin Munthe
DP | Director
