sony handycam to DVD problems
hi guys
first off this is my first plunge into the (scary) world of video.. and have already hit a snag.
im using a sony handycam HDR-CX 150 and using final cut pro 7 on a macbook pro..
the problem is that i shot the footage i needed on the ‘SD HQ’ on the camera without realizing, but i can use it to burn to DVD. but when i import it into FCP it looks great in the canvas but as soon as i burn or even just compress to DVD BEST 90 mins the video is 100 times worse..
i was told that it is maybe my ‘easy setup’ settings that they are not configured right.. i cant re-shoot the footage so i have to try and do my best the get it looking good as possible.. heres some of the details of the file im working with:container: Mpeg Program Stream
bitrate: 8082 Kps
format: MPEG-2 Video
Frame size: max undefined, average 25.000, min undefined
bit rate: variable
resolution: undefined
width: 720
height: 576
pixel aspect ratio: 64:45
display aspect ratio: 16:9
interlacing: interlaced – top field firsti feel i should mention it was shot in landscape and i will need to rotate to portrait. i just basically need the best way to maximise the footage i have plus with the addition of a small AC3 file which is no problem BTW.. ( one thing i can do ;)! )
Any Help is greatly appreciated as neither compressor or DVD studio Pro could resolve the problem
