Activity Forums DaVinci Resolve Sony F55 XAVC HD clips in Resolve Roundtrip with Avid – What format do you render them as?
  • Sony F55 XAVC HD clips in Resolve Roundtrip with Avid – What format do you render them as?
    Posted by Scott Clements on October 29, 2013 at 1:26 am
    I’m having trouble figuring out the Avid/Resolve XAVC HD workflow.
    When you’ve brought your AAF into Resolve (that’s ama linked to XAVC HD clips), you grade them and then when you go to do your final render, you select the “Avid AAF Roundtrip” easy setup. You “Render to:” MXF. But, I get stuck here – under the section “Codec is:” …… What do you render all the graded clips as? There’s no “same as source” or XAVC option, so which format do you render to to preserve all the information? Anyone have experience with this workflow? Many thanks.
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 12 years, 10 months ago 2 Members · 4 Replies
