Activity Forums Adobe Premiere Pro Sony F55 mxf import into Premiere Pro
  • Sony F55 mxf import into Premiere Pro
    Posted by Kinga Rup on September 3, 2016 at 5:31 pm
    Hello,
    it’s a beginners question 🙂 I’m going to edit footage recorded on Sony F55. The crew gave me disc containing files “proxyfootage” which looks like this:
    Can anyone kindly tell me if this is indeed transcoded data ready to be imported into Premiere PRo CC (I’m working on PC) or what is the workflow (do I only need special plug in?)
    Many thanks in advance!
    Kinga Rup replied 10 years ago 2 Members · 2 Replies
  • Shane Ross
    September 3, 2016 at 9:37 pm
    That’s not transcoded, that’s the raw dailies. You should be able to bring in the MXF files directly using the Media Browser
    Shane
    Little Frog Post
  • Kinga Rup
    September 4, 2016 at 9:00 am
    Hi Ross,
    thank you so much! It was a bit confusing: I’ve received two files “proxyfiles” the one containing files as on the screenshot I used before and also “rawfootage” which looks like below:
    containing these:
    I could bring files using media browser, but error message appears:
    file directory:
    error:
    Would it be best now to transcode the files to use in Premiere, and what codec/format should I use (there is quite a lot of material, it’s a short film, school project). The “rawfootage’ is recorded in 4k (F55 raw sq) 24 fps. The “proxyfootage” is XAVC Mpeg4. Should I now best transcode the “rawfootage” files using Resolve to HD, Quicktime, H.264 for Premiere or another codec would be better? Any watchouts (probably lots 🙂
    I’m really really thankful for this! 🙂
