Activity Forums Apple Final Cut Pro Sony F55 4K workflow in X?
  • Sony F55 4K workflow in X?
    Posted by Charlie Austin on June 14, 2013 at 6:35 pm
    Anyone got a workflow they could pass along? Have a gig coming up and need it to work well. Thanks in advance!
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
    Doug Suiter replied 12 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • James Cude
    June 14, 2013 at 7:44 pm
    Will you be using Sony’s RAW format, XAVC compressed 4K or capturing the live output to a 4K outboard recorder such as a KiPro Quad?
  • Charlie Austin
    June 14, 2013 at 7:50 pm
    [James Cude] “Will you be using Sony’s RAW format, XAVC compressed 4K or capturing the live output to a 4K outboard recorder such as a KiPro Quad?”
    Not a clue… will find out and post here. Thanks!
  • Charlie Austin
    June 14, 2013 at 9:44 pm
    [James Cude] “Will you be using Sony’s RAW format, XAVC compressed 4K”
    Still no word, guessing XAVC, but who knows. Really just looking for potential gotchas etc. probably only about 3 minutes long, but It’s all green screen. Should be fun… 😉
  • James Cude
    June 14, 2013 at 10:04 pm
    I would definitely try to nail it down before they shoot, 4K’s not exactly in a we’ll show up with tapes so make it work state just yet.
  • Francois Jean
    June 14, 2013 at 11:11 pm
    Hi
    I presume you did get this sony plugin
    https://community.sony.com/t5/F5-F55/XAVC-APPLE-FCPX-plugin/td-p/107431
    I also use the new content browser to generate MXF wraped clips ( see info at Sony)
    https://www.sonycreativesoftware.com/contentbrowser
    regards
    ZAP
  • Charlie Austin
    June 20, 2013 at 11:43 pm
    OK… here’s what I got… in a folder on a drive. I can see and import the SXS-PROXY files, but Neither FCP X or Sony Content Browser will see the 4k RAW files… Now what? 🙂
  • Doug Suiter
    July 14, 2014 at 12:34 am
    I am about to embark on a project with the same format as you – I’d be interesting in how things went for you. Anything to report?
