Activity › Forums › Sony Cameras › Sony EX3 not downloading to NEXTO portable drive
  • Sony EX3 not downloading to NEXTO portable drive
    Posted by Roy Stewart on October 23, 2010 at 8:19 pm
    I have a Sony EX3 and recently purchased a NEXTO portable drive – but I cannot get the EX3 to see the NEXTO via the usb connection.
    When I connect the same camera to my MAC to copy the video footage into Final Cut pro, there is no problem – so it cannot be the camera or the usb cable.
    The problem only occurs when I connect the ex3 to the NEXTO. It simply does not see it to connect to.
    Can anyone advise please?
    Joseph Kim replied 15 years, 5 months ago 5 Members · 4 Replies
  • Klaas Van urk
    October 24, 2010 at 9:46 pm
    The Nexto has a USB port that makes connection to a computer. The EX3 has also a USB port that is suited to make connection to a computer. Both having a USB port doesn’t mean that they can be connected to each other (or ‘see’ each other). The Nexto is suited to offload cards in the field. As far as I know it doesn’t have a SXS card slot. A workarround may be using a MXR card adaptor (or alike) plus a SDHC card in your EX3 and then offload the SCHC cards in your Nexto. But offloading cards in the field is not seen as a safe way of working.
  • Bruce Rawlings
    October 25, 2010 at 7:31 am
    SDHC cards can be downloaded to the Nexto 2500 from the sdhc slot. Nexto does not recognise in my case the MxR adaptor when put in Expresscard slot.
  • Les Wilson
    October 28, 2010 at 11:25 pm
    According to the NexTo site, it’s supposed to work by connecting the camera to the device via the USB. From their site for the NexTo Video Storage model: “With NEXTO Video Storage, you simply connect the device to your camcorder via USB port ”
    https://www.nextodiusa.com/product_info.asp?nexto_product=2
  • Joseph Kim
    April 6, 2011 at 6:41 am
    Not all camcorders. Though Nexto ND-2725 can be connected with EX-1/-3 via USB, but it’s very slow.
    Hope this information helps.
    Jk
