Activity Forums Sony Cameras Sony EX1 Cannot proceed (Histogram)
  • Sony EX1 Cannot proceed (Histogram)
    Posted by Frank Mulder on January 21, 2013 at 3:26 pm
    Hello,
    I’m curious, … does anyone know when I press the ‘Histogram’ button on my EX1, the display shows ‘cannot proceed’?
    No, it’s not the ‘Direct Menu’, cause that one is set to ‘Part’ and only disallows gain etc.
    I even recalled the camera data, so the camera is in our default mode, which normally lets me use the Histogram-function. I checked with another EX1, which did not have this problem…..
    Finally I did an ‘All reset’ and again read my camera data into the EX1…… now I have my Histogram back ……
    ….but why couldn’t I get it in the first place?
    Cheers
    Jim Vlies replied 13 years, 8 months ago 3 Members · 5 Replies
  • Jim Vlies
    January 21, 2013 at 4:01 pm
    I don’t know, with my ex1r, I cannot see histogram in SD mode. but on EX1 i don’t know. so sorry for the not very helpful response 🙂
  • David Wheeler
    January 22, 2013 at 1:55 am
    The histogram button can be assigned to another function in the OTHERS menu, such as “rec review” or “last clip delete.” You may have had it assigned to a function that could not be performed. All reset would have restored the default assignments.
    David Wheeler
    EX1R; EX3; nanoFLASH; FCP 7; 17″ MBP, MacPro Quad, Matrox MSO2,CS5
    dave@marcombiz.com
  • Frank Mulder
    January 22, 2013 at 6:39 am
    Thanks for replying David. Your suggestion though could not have been the cause, for I had re-entered our templateconfig from a card we use.
    In the menu (submenu display On/Off) the Histogram option was greyed out. So even there it was not possible to activate the histogram.
    It was Jim’s suggestion that did the trick.
    Thanks anyway for replying.
    Cheers.
  • Frank Mulder
    January 22, 2013 at 6:50 am
    That’s no problem Jim. You not being helpful was actually …. quite helpful 😉
    I did not mention that I had this problem on the EX1r (and I compared it with a different camera …. yep an EX1).
    What I did not expect was that when I re-entered the config from a card, the SD/HD mode is not being reset. I assumed that everything would be back to our basic settings.
    The camjo-colleague told me he had shot in HD (for his TV-monitor he was using during edit could only show SD and thus he could not use that device). But I guess he must have played around in the menu and set it to SD. He told me though that he did not alter the menu … only the output was set to SDI.
    Well, now I know that he was not telling the truth, the whole truth and nothing but the truth. (may God help him, when I see him ;-))
  • Jim Vlies
    January 22, 2013 at 8:18 am
    Ok. Very good! Good start of my day! Thnx.
