Activity › Forums › Apple Final Cut Pro Legacy › Sony EX-1 .MP4 file import issue
  • Sony EX-1 .MP4 file import issue
    Posted by J.p. Welgus on May 27, 2009 at 8:56 pm
    Thank you in advance. I have a client that supplied me with a hard drive of .mp4 clips that was shot on a Sony EX-1 camera 1080p 23.98fps. Unfortunately I am unable to import any of these files. I have tried Final Cut 6, Compressor, Telestream Episode Engine, Sony XDCam transfer, to no avail. I believe that I downloaded all the possible drivers. The only way I am able to view the files is through VLC.
    All of the previous information I have seen regarding issues importing from the Sony EX-1, the people had the luxury of having the SxS cards available (I do not). Is it possible that one cannot import from a Hard Drive, or are my files corrupt?
    Again thank you.
    JP Welgus
    Apex Stock
    Director of Content
    Daniel Wright replied 15 years, 11 months ago 11 Members · 14 Replies
  • 14 Replies
  • Chris Babbitt
    May 27, 2009 at 8:59 pm
    The files should be in a folder labeled BPAV, and that folder should reside inside another folder. If that’s the case, you’ll need the Sony XDCAM Transfer software to convert the files for FCP use. If it’s not in that configuration, you’ll need to have your client re-submit it exactly the way it comes off the cards, or, better yet, as Quicktime EX clips that have been processed by the Transfer software.
  • John Fishback
    May 27, 2009 at 9:05 pm
    MPEG Streamclip https://www.squared5.com/svideo/mpeg-streamclip-mac.html might be able to convert the files to a useable QT codec. That would be time-consuming to do many files and might result in a degradation of quality as compared to a more direct input to FCP. Hopefully, someone with XDCAM experience will have an answer for you.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Kip Cole
    May 27, 2009 at 9:13 pm
    JP, you can import XDCAM footage from either SxS cards or a hard drive, but you will need the XDCAM Log and Transfer plugin for FCP.
    For some reason it is hard to find. You can do a search for “XDCAM Plugin” or try this site: https://www.sony.ca/xdcamex/software.htm. Scroll down to the bottom of the page and download the version 2.5.1 file. I read that they’ve gone as high as 2.7, but this was the only version I could find. I works fine with my Macbook Pro. Someone else on this forum may know where to get a more recent version.
    Once you install the plugin, “XDCAM” becomes one of your options under the import function.
    Good Luck!
    Kip Cole
    WKNO-TV
    Memphis
  • Jeremy Garchow
    May 27, 2009 at 9:30 pm
  • J.p. Welgus
    I just would like to thank everybody that has provided information to assist me on my issues. Now I am off to try these suggestions. Hopefully everything works out. Again thank you.
    JP Welgus
    Apex Stock
    Director of Content
  • Chris Borjis
    May 27, 2009 at 9:31 pm
    [Kip Cole] “For some reason it is hard to find.”
    you ARE talking about Sony here…. 🙂
  • J.p. Welgus
    May 27, 2009 at 9:33 pm
    Yep, should have saw this a mile away 🙂
    JP Welgus
    Apex Stock
    Director of Content
  • Jeremy Garchow
    May 27, 2009 at 9:46 pm
    [Don Greening] “The Sony transfer tool app. (free) is to re-wrap the EX .mp4 files to MOV format otherwise FCP will not see the files.”
    You can with this:
    https://calibratedsoftware.com/MP4EXImport_Mac.asp
  • Don Greening
    May 27, 2009 at 9:56 pm
    Nobody’s mentioned it yet but the minimum software requirements for viewing/editing XDCAM EX files with FCP are:
    • Final Cut Pro v.6.0.2 or better
    • Quicktime v.7.3.1 or better
    • Mac OS v.10.4.11 or better
    • Sony Transfer tool v.2.5.1 or better
    The Sony transfer tool app. (free) is to re-wrap the EX .mp4 files to MOV format otherwise FCP will not see the files. As was mentioned each BPAV folder should reside within another uniquely named folder, otherwise the Transfer tool will not see the files. The BPAV folder should not be named anything other than “BPAV”.
    – Don
  • J.p. Welgus
    May 27, 2009 at 11:03 pm
    Thank you all for your support. I truly believe that the files are corrupt. All of the possible solutions that everyone has presented to me still come back either: invalid data, error trying to open source media file, access denied or unknown. If i stumble across something I will let you know.
    JP Welgus
    Apex Stock
    Director of Content
