Activity Forums Apple Final Cut Pro Legacy Sony DSR-1500A Deck
  • Sony DSR-1500A Deck
    Posted by Tim O’grady on April 28, 2005 at 10:46 pm
    We’re thinking of buying a Sony DSR-1500A deck and would like to know if there are any issues when using this deck with FCP. I’ve searched the posts and have found a couple of minor problems that can be fixed. Sony says the deck will playback DVCPRO but “will not output DVCPRO through its optional digital boards”. Does that mean it will not play back through firewire, and therefore not capture from a DVCPRO tape into FCP?
    Tim
    Scott Evans replied 15 years, 11 months ago 6 Members · 7 Replies
  • 7 Replies
  • Adam Schmidt
    April 28, 2005 at 11:07 pm
    You got it right. Sony will not play Pani over FW, and the reverce is true. Pani is coming out with a DVCPRO deck (it was at nab) in the $5000 range that can play DVcam over FW, it might be better for you. The 1500 is a good DV deck, but I can see the end of DV coming, heck I have not tuched the stuff for over two years now.
    adam
  • Tim O’grady
    April 28, 2005 at 11:19 pm
    Adam
    Thanks for the quick reply, POs are due soon and it sounds like we need to do a little more research. Any word from Panasonic on when that deck would be available?
    Tim
  • Michael Smith
    April 29, 2005 at 12:59 am
    seems to be good as a feeder deck only
    assemble from FCP not frame accurate
    insert not available without special cards
  • Aaron Neitz
    April 29, 2005 at 4:32 pm
    Optional Digital Boards? We have the 1500A with the optional SDI I/O board and it will play back DVCPRO-25 just fine from there. (note, the deck won’t playback DVCPRO-50) The deck gets used heavily as a loaded for dailies on DVCAM and has never given us problems. The auto tension warning has saved several tapes by stopping down the deck and refusing to do anything further (you take off the cover and gently extract by hand. tapes were saved)
    The only drawback is it MUST be on its own firewire bus, so you’ll have to get a cheap PCI firewire card.
  • Sam Zimman
    April 29, 2005 at 5:15 pm
    It will playback DVCPro-25 through SDI, but not through the optional Firewire board. This means you can not edit in native DVCPro-25 codec. So, if you get a lot of DVCPro-25 footage, you should realize that you would have to capture over SDI to Un8, or DV, or DVCPro, or whatever codec you want to get with. You will not get an exact duplication of the data on the tape. It will be decoded, played over SDI, and FCP will encode it to whatever codec you want. This sounds like a lot of room for encoding errors, but it’s no worse than what you do with a Digibeta.
  • Tim O’grady
    May 1, 2005 at 1:25 am
    Thanks for all your input guys!
    Tim
  • Scott Evans
    October 12, 2010 at 8:23 pm
    1500A plays back DVCPRO 25 just fine through firewire connection.
    Cheers!
