Activity › Forums › Blackmagic Design › Sony BVW 40P and Decklink SP ? would this work?
  • Sony BVW 40P and Decklink SP ? would this work?
    Posted by Olivier Jean on April 10, 2005 at 10:27 pm
    Hi guys,
    would you know if the ancient Sony BVW 40P
    would work with a Decklinp SP System??
    Info on this deck is scarse,
    it has rs422 deck control but the component input/output is via a
    circular 12-pin connector and
    not the familiar triple of BNC connectors.
    is there any adaptor out there to convert the output
    to bnc??
    thx for any kind of info.
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
    Olivier Jean replied 21 years, 5 months ago 2 Members · 3 Replies
  • Dalen Quaice
    April 11, 2005 at 1:26 am
    You could capture via the composite BNC if nothing else. The decklink should control the machine as it’s standard “BVU-800” protocol VTR. There are breakout cables kicking about here in the US, but you could build yourself as the standard betacam components Y: 1.0Vp-p, 75 ohms sync negative R-Y: 0.7Vp-p, 75 ohms B-Y: 0.7Vp-p, 75 ohms are present on the pinouts – just wire these to BNCs and it should work.
  • Dalen Quaice
    April 11, 2005 at 2:28 am
    https://www.comprehensiveinc.com/compvideo/search.asp?keyword=12%20pin
    Comprehensive make the ones we have around the studio I notice…don’t know if you can get them in your area.
  • Olivier Jean
    April 12, 2005 at 9:34 am
    Hi Dalen,
    thanks for your answer, the cow is a great place…
    Regards
    Olivier Jean
    Powermedia Systems
    Sydney Australia
