Activity Forums VEGAS Pro Sony AVC Codec vs. MainConcept AVC
  • Sony AVC Codec vs. MainConcept AVC
    Posted by Scott Mitchell on April 21, 2011 at 11:51 pm
    So, I’ve been experimenting with this codec a bit and really like the quality. NOTE: I am experimenting on Vegas Pro 10.c
    Our 2 person subjective opinion of Sony AVC vs. MainConcept is that Sony AVC provides much higher quality given the same (similar) settings. We see less blocking on blacks/shadows and higher quality when zooming in on faces. In addition, it is 3x faster encoding (I have an Intel i7 920 with 12MB RAM).
    However, there are a number of very odd issues. For example, using Sony AVC, I selected Main Profile and (what I thought was) Constant 4,000,000 bps.
    Here is my MediaInfo from the output file. It notes High Profile (High@L4.0) and the bitrate is Variable.
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=15
    Muxing mode : Container profile=Main@3.1
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 26s 26ms
    Bit rate mode : Variable
    Bit rate : 3 406 Kbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.123
    Stream size : 10.6 MiB (93%)
    Language : English
    Encoded date : UTC 2011-04-21 23:33:52
    Tagged date : UTC 2011-04-21 23:33:52
    Has anyone else experimented with Sony AVC?
    Scott Mitchell replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
