Activity Forums VEGAS Pro Sony Architect Pro 5.2 – Blu-ray Authoring problem
  • Sony Architect Pro 5.2 – Blu-ray Authoring problem
    Posted by Quinn Vu on July 25, 2011 at 5:50 pm
    Hello,
    I have been pulling my hair out in past few days trying to author a menu-based Blu-Ray disc using Sony Architect Pro 5.2. No matter what I tried, it would stuck at %1 render for a while then return with this error:
    “Warning: An error occurred while writing a file.”
    “Error 0x8004e02c (message missing)”
    If I choose to make single-movie instead of menu-based, then everything would be fine. With menu-based, If I were to change the project properties to “make DVD” instead of “make Blu-ray” then it would compile fine after going through recommpression.
    My work flow:
    Files rendered from Vegas 10D using MainConcept MPEG-2 templates:
    = Blu-ray 1920×1080-60i, 25 MBps video stream
    (29.970 fps, 1920×1080 Upper field first, YUV, 25 Mbs, Pixel aspect ratio: 1.0)
    Dolby Digital AC-3 Pro (256 Kbps, 48Khz, 24 Bit, Stereo, AC3)
    Importing into Sony Architect 5.2:
    Video: xxxx.m2v
    Audio: xxxx.ac3
    Project properties:
    Disc format: Blu-ray disc
    Target media size(GB): 25
    Video format: MPEG-2
    Bit rate (Mbps): 25.000
    Aspect ratio: 16:9
    Resolution: 1920×1080
    Frame rate: 29.970 interlaced
    Progressive: No
    Audio format: AC-3 Stereo
    Bit rate (Kbps): 448
    Before upgrading for Sony Architect Pro 5.2, I were using version 4.5 to successfully author many menu-based DVD disc.
    I have tried another computer with same result and really need your help.
    Thanks in advance.
    Quinn Vu replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
