Activity Forums Adobe After Effects Expressions Something similar to the vehicle rig example
  • Something similar to the vehicle rig example
    Posted by Ken Latman on July 13, 2009 at 5:47 pm
    I’m trying to make an animation in which a series of rollers move an object along a path. I want each roller to rotate as if it is pushing the object along. Something similar to the way a pitching or tennis ball machine work. You have two wheels spinning and when something gets in between it pushes it along.
    I looked at the Vehicle rig tutorial provided by the Cow and just didn’t parent my wheels to an object.
    The problem I have now is that all the wheels are in the same alignment and look very bland. How can I offset each wheel’s starting rotation without effecting the intial expression?
    d=width;
    pi=Math.PI;
    circ=d*pi;
    rot=360/circ;
    moveY=thisComp.layer(“My Move Layer”).transform.position[1];
    rot*moveY
    Each wheel I create has this expression but unfortuntely when applied they all start back at the same rotated start.
    Ken Latman replied 17 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 13, 2009 at 6:13 pm
    This should work:
    d=width;
    pi=Math.PI;
    circ=d*pi;
    rot=360/circ;
    seedRandom(index,true);
    offset = random(360);
    rot*moveY + offset
    Dan
  • Ken Latman
    July 13, 2009 at 7:43 pm
    Once again day I can not thank you enough!
