Activity › Forums › Adobe After Effects › something like a rapid hair removal solution ?
  • something like a rapid hair removal solution ?
    Posted by Sebastien Allain on April 24, 2007 at 1:36 pm
    hello,
    I have to remove a lot of hair on a 2k film…
    So much hair that I’m looking for a rapid removal solution.
    The clone tool in AE is not the right way to me because of a lot of pan movement.
    I’ve try the CC wire removal plug in which is a good idea of displacement+fade way for straight line…
    what about a tool for curves ? Something able to work along a rotobezier mask for example.
    Please, I hope your advice
    sebastien
    Sebastien Allain replied 19 years, 5 months ago 4 Members · 6 Replies
  • Darby Edelen
    April 24, 2007 at 3:41 pm
    I think you might want to look at Mokey from Imagineer Systems (https://www.imagineersystems.com/). Any way you cut it it’s going to be a pain in AE, Mokey would make it a lot easier although not necessarily automatic!
  • Mike Clasby
    April 24, 2007 at 8:04 pm
    Can you post an example?
  • Sebastien Allain
    April 24, 2007 at 10:10 pm
    of course yikesmikes,
    please download this SD preview:
    https://www.apt-a.com/hair-removal-pvw.jpg
    sebastien
  • Darby Edelen
    April 25, 2007 at 2:41 am
    Ouch… If the hair is only there for a frame or two then the clone tool might give you okay results. But I’m tellin’ ya, I saw mokey in action at NAB and it would make quick work of this.
  • Majorasshole
    April 25, 2007 at 5:20 am
    Mokey is also really really expensive. Somewhere around $9000-12000US for fixed of floating licenses.
  • Sebastien Allain
    April 25, 2007 at 7:17 am
    Unfortunately, each hair are fixed across a lot of take…
    In fact, do you think that Mokey can remove such hair over long shot ?
    and do you think it’s realist in term of working time / rendering time ?
    (mokey tracker seems to be very long to perform such good job)
    sebastien
