some videos are choppy, some are not
Posted by Jarek Hanzelka on April 12, 2008 at 6:58 pmHello SV users! I hope someone can help me in this. I started a little project – a big music video combined by many videos. When I started it, everything was perfectly smooth. Then I saved the file so I can continue later. Then, some video were extrmely choppy and some are still smooth. Why? I also hope someone can tell me how to fix this problem. Thanks!
Edward Troxel replied 18 years, 5 months ago 4 Members · 8 Replies -
Laszlo Kovacs
April 16, 2008 at 6:36 pmHi,
Where do you see it choppy? On the preview, or in the rendered file?
Regards
K.L.
Jarek Hanzelka
April 16, 2008 at 7:12 pmIn the preview. I didn’t try to render it, because I will need those vids smooth in preview as well. You know, there is a smooth scene, after it is for example 1 second choppy scene, so she doesn’t even jump in the preview and I need to see it…
Theo Van laar
April 16, 2008 at 7:16 pmJust select the part of the timeline that shows bad prview and go to the menu: TOOLS-SELECTIVELY PRERENDER VIDEO (make sure that RENSER LOOP REGION ONLY is selected!)
Theo
Theo Van laar
April 16, 2008 at 7:55 pmWhy are you not allowed to select RENDER LOOP REGION ONLY? Could it be that you didn’t make a selection yet on the timeline?
Another way to improve your poor preview is to select this region on the timeline and select on the menu bar TOOLS-BUILD DYNAMIC RAM PREVIEW.
Theo
Jarek Hanzelka
April 16, 2008 at 8:16 pmThat was it, I actually just clicked it first, my bad.
Anyway, after the prerendering was done, the preview of the vid was smooth again. A tried to build dynamic RAM preview on different choppy vid and it did smooth it a bit, but not totally. But don’t tell me that I’ll have to do this everytime I save the project and then open it again? -
Theo Van laar
April 16, 2008 at 9:28 pmA RAM preview is temporaly, until you empty your RAM memory. However, it is supposed to be faster then a PRERENDER. But the PRERENDER is saved on your harddisk and is still there whene you open Vegas againn. The Prerendered file remains valid until you change something on this region….
A real permanent issue would be the option RENDER TO A NEW TRACK (Ctrl M).Theo
Edward Troxel
April 17, 2008 at 8:25 pm
