Activity Forums VEGAS Pro Some questions for the experts
  • Some questions for the experts
    Posted by Sebastian Rivera on December 22, 2008 at 9:54 pm
    Hello , and thank you in advance for the help.
    I have a blue square graphics in a black baground I wanted the black to dissaper so I could see through to another video but the leave the blue graphic in front. I did this using Chroma Key and selecting the black with the dropper.
    Now everything worked as I wanted but the problem is that I get a black border around my blue square graphic. I dont want that black outlining parts of the square(it didn’t key out) how do I get rid of it?
    my second question is , I want a 130 angle drop shadow in my text, I go to effects in the text box and I chekmark “draw shadow” and move the x offset and y offset but how do I know what number is the 130degree angle ?
    thank you again
    Sebastian Rivera replied 17 years, 9 months ago 4 Members · 6 Replies
  • Steve Keliher
    December 23, 2008 at 1:19 am
    No idea on the black border, sorry, but using trigonometry, to get 130 degrees, you need an x of -0.643 and a y of 0.766
  • Joe Mantaratz
    December 23, 2008 at 3:08 am
    I’m a little confused as to why you would chroma key out the black background. If I understand you correctly you have a track with media generated black color with a blue graphic in the foreground and you want to remove the black background and have the graphic remain behind the blue graphic while revealing another video. The easier way to do this is to insert your video on the bottom track and place in the timeline where you would like it to appear. Then simply either cut the black background at the same time or lower it’s opacity an envelope an add the nodes along it. Chroma key allows other things to show through and if you are removing the black and it is the top track then you will still be left with black everywhere else. Let me know if this helps or I am missing the point.
    Joe
  • Sebastian Rivera
    December 23, 2008 at 8:14 am
    Thank you Steve and Joe for the help
    I am uploading an image for you to see the problem . I am new to Sony Vegas so detailing the process on how to get rid of the black lines that remain , would be helpful .
  • Sebastian Rivera
    December 23, 2008 at 8:17 am
  • Omer Aydin
    December 23, 2008 at 3:02 pm
    If the blue box is not moving or animated, I’d draw a beizer mask around it with tangents at corners.
    Or duplicate the Blue box layer,
    switch composition mode of the upper layer to Mask,
    make the lower layer a child track,
    go in track motion of the upper track and scale down the Mask layer size a bit to crop the black areas out.
  • Sebastian Rivera
    December 23, 2008 at 8:28 pm
    thank you Omer
    I found out what I wanted , in order to get rid of the black outlines
    just select the clip go to properties alpha channel an select premultiplied .
    thanks again
