Activity Forums Maxon Cinema 4D Some Particles passing through Collider?
  • Some Particles passing through Collider?
    Posted by Tony Barone on August 12, 2011 at 9:50 pm
    I am trying to create an animation where particles, in this case small spheres, exit a emitter and collide with a table surface.
    I’ve applied rigid body dynamics to the sphere within the emitter, and applied a collider tag to the table surface.
    For some reason, even though most of the spheres bounce off the table, there are some, probably 15% or so, that pass directly through the table surface with the collider tag.
    Is there any way to prevent them from passing through?
    Tony Barone replied 15 years ago 2 Members · 2 Replies
  • Brian Jones
    August 13, 2011 at 1:05 am
    if the particles are moving pretty fast you can increase the Steps Per Frame in the Dynamics/Expert tab in the Document settings.
  • Tony Barone
    August 13, 2011 at 1:28 am
    Thank you VERY much!
