Activity › Forums › Square Box CatDV › Some mp4 proxys can’t be played in CatDV PRO 9.0.5 // Confusing behavior
  • Some mp4 proxys can’t be played in CatDV PRO 9.0.5 // Confusing behavior
    Posted by Leonid Nekrasov on February 24, 2012 at 10:40 am
    I have a very strange Bug. Some MP4-Files can’t be used as proxy clips. I tried different settings and codecs. It’s all the same. The only similar thing about this clips: they all were made by Telestream Episode. I can import them and play them as a normal Mediafiles in a Catalog. But when I want to use them, as a proxy medias, the catdv pro failures to play them. The proxys are online and can be seen by catdv pro. The Paths are o.k..
    As you will see from the Log File, the error “quicktime.std.StdQTException[QTJava:7.6.6g],-2015=invalidTime,QT.vers:7668000” appears, if I try to play proxy clip. The same clip can be played, when it used as a normal mediafile (when I import it in my Catalog). When I use a mp4 file created by Quicktime, no errors appears. It can be played by catdv pro.
    Is it a known issue?
    Do you know any workaround?
    Thanx for any suggestions and regards
    Leonid
    Hier is the Testfile:
    3760_test2h264mp4512kbit.mp4.zip
    And hier is the Log File:
    [10:13:04.054]
    Starting helper Fri Feb 24 10:13:04 CET 2012
    apple.awt.UIElement = true
    awt.nativeDoubleBuffering = true
    awt.toolkit = apple.awt.CToolkit
    catdv.mainClass = squarebox.catdv.mf.remote.server.Server
    file.encoding = MacRoman
    file.encoding.pkg = sun.io
    file.separator = /
    ftp.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
    gopherProxySet = false
    http.nonProxyHosts = local|*.local|169.254/16|*.169.254/16
    java.awt.graphicsenv = apple.awt.CGraphicsEnvironment
    java.awt.printerjob = apple.awt.CPrinterJob
    java.class.path = /Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/catdv.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/crimson.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/resources.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/jakarta-regexp-1.5.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/jakarta-poi-1.10.0-dev.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/jmf.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/fobs4jmf.jar:/Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/extensions.jar:/Library/Application Support/CatDV/extensions.jar:/usr/local/xuggler/share/java/jars/xuggle-xuggler.jar
    java.class.version = 50.0
    java.endorsed.dirs = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/endorsed
    java.ext.dirs = /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/ext
    java.home = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
    java.io.tmpdir = /var/folders/eI/eI5E+RrfFLObfYK3aGpPLk+++TY/-Tmp-/
    java.library.path = /Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java:/usr/local/xuggler/lib:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources
    java.runtime.name = Java(TM) SE Runtime Environment
    java.runtime.version = 1.6.0_29-b11-402-10M3527
    java.specification.name = Java Platform API Specification
    java.specification.vendor = Sun Microsystems Inc.
    java.specification.version = 1.6
    java.vendor = Apple Inc.
    java.vendor.url = <a href='https://www.apple.com/'>https://www.apple.com/</a>
    java.vendor.url.bug = <a href='https://bugreport.apple.com/'>https://bugreport.apple.com/</a>
    java.version = 1.6.0_29
    java.vm.info = mixed mode
    java.vm.name = Java HotSpot(TM) Client VM
    java.vm.specification.name = Java Virtual Machine Specification
    java.vm.specification.vendor = Sun Microsystems Inc.
    java.vm.specification.version = 1.0
    java.vm.vendor = Apple Inc.
    java.vm.version = 20.4-b02-402
    line.separator =
    mrj.build = 10M3527
    mrj.version = 1060.1.6.0_29-402
    os.arch = i386
    os.name = Mac OS X
    os.version = 10.6.8
    path.separator = :
    socksNonProxyHosts = local|*.local|169.254/16|*.169.254/16
    sun.arch.data.model = 32
    sun.boot.class.path = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsfd.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/classes.jar:/System/Library/Frameworks/JavaVM.framework/Frameworks/JavaRuntimeSupport.framework/Resources/Java/JavaRuntimeSupport.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/ui.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/laf.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/sunrsasign.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jsse.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/jce.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes/charsets.jar
    sun.boot.library.path = /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries
    sun.cpu.endian = little
    sun.cpu.isalist =
    sun.io.unicode.encoding = UnicodeLittle
    sun.java.command = squarebox.catdv.SecureLauncher
    sun.java.launcher = SUN_STANDARD
    sun.jnu.encoding = MacRoman
    sun.management.compiler = HotSpot Client Compiler
    sun.os.patch.level = unknown
    user.country = DE
    user.dir = /Applications/CatDV Pro 9.0.5
    user.home = /Users/leonid
    user.language = de
    user.name = leonid
    user.timezone = Europe/Berlin
    [10:13:05.228]
    @1 open
    [10:13:05.376]
    Searching for catdv_de.txt, library path len=3
    Not found, falling back to English
    Searching for catdv_en.txt, library path len=3
    Loading language file /Applications/CatDV Pro 9.0.5/CatDV Pro.app/Contents/Resources/Java/catdv_en.txt
    Successfully loaded 4565 entries
    [10:13:05.596]
    created SourceMedia['null',start=0:00:00.0,end=null,video=(Various),audio=(Various),still=false,numFrames=0,importer=null,startFrame=0,movieStart=0,movieFrames=0,movieDuration=0,qttc=null]@ab444
    [10:13:05.656]
    Error processing: @1 open
    at quicktime.std.StdQTException.checkError(StdQTException.java:40)
    at quicktime.std.movies.Movie.insertSegment(Movie.java:1458)
    at squarebox.catdv.qt.$1.$0(Unknown Source)
    at squarebox.catdv.mf.remote.server.$0.$12(Unknown Source)
    at squarebox.catdv.mf.remote.server.Server.$1(Unknown Source)
    at squarebox.catdv.mf.remote.server.Server.$0(Unknown Source)
    at squarebox.catdv.mf.remote.server.Server$2.run(Unknown Source)
    at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:199)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:677)
    at java.awt.EventQueue.access$000(EventQueue.java:85)
    at java.awt.EventQueue$1.run(EventQueue.java:638)
    at java.awt.EventQueue$1.run(EventQueue.java:636)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:647)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
    Leonid Nekrasov replied 14 years, 5 months ago 5 Members · 9 Replies
  • 9 Replies
  • Kevin Duggan
    February 24, 2012 at 3:44 pm
    Hi Leonoid
    so do they have the exact same name as the source and have you created a Path Based directory structure within the Proxy folder ? , and as usual is the path to the proxies correct. Do a quick test by building the proxies from within the Catdv client interface , Menu > Media > Build Proxy Media
    Kevin Duggan
    CatDV/MME
  • Leonid Nekrasov
    February 27, 2012 at 7:45 am
    Hi Kevin,
    the Problem seems to be the compatibility between the mp4 files and the CatDV. The Proxys were build in a proper way. The Paths and the naming are correct. I checked this by exchanging the not working mp4 testfile by another mp4 (that was created with MPEGStream Clip) with the same name. In that case everything worked fine.
    I am confused because my mp4 files causes a strange behavior. If they wouldn’t work at all, it would be clear. But they work in the slider “Movie” (if I use them as main assets, by importing in the catalog) and don’t work in the slider “Proxy” (if I try to use them as a proxy files) in CatDV Pro. I don’t know how CatDV build, but it seems that two different engines trying to play the same moviefile, and the proxy one fails.
    Regards,
    Leo
  • Rolf Howarth
    February 27, 2012 at 12:38 pm
    Thanks for the file. We do see some “invalid time values” warnings with that file which might explain why it doesn’t work as a proxy but we’ll investigate and let you know.
  • Brad Starkey
    February 27, 2012 at 5:18 pm
    The file plays as a Proxy on my system. I’m on version 9.0.6. Try downloading the latest version of CatDv.
    The invalid time values is an Episode bug. They are aware of it.
    https://forums.creativecow.net/readpost/278/1895
  • Leonid Nekrasov
    February 27, 2012 at 9:01 pm
    Ah. o.k.. I see. It’s a pity i didn’t mentioned your post before, even though I searched the forum for some similar issues. But you have just the same problem as I have. It is often so difficult to spot the cause of the problem, when so many elements are involved in a workflow.
    The Telestream distresses me more and more. I use different Telestream products and have always some confusing problems with them.
    So it seams I can’t use the expensive episode encoder I just bought for building proxys. Hm…
    I will try the CatDV 9.0.6 asap.
    Thank you very much!
    Regards
    Leo
  • Matthew Stamos
    February 28, 2012 at 10:33 pm
    You can use the command line interface of Episode engine to create the equivalent directory and use it to make proxies.
  • Leonid Nekrasov
    March 15, 2012 at 11:14 am
    Hi Brad,
    I’m still wondering how you got the clip running on your system. I tried all possible settings in Episode.
    My System:
    Mac OS 10.6.8
    Quick Time Player (Version 10.0 (131))
    Quick Time Player (Version 7.6.6 (1709))
    CatDV Pro 9.0.6
    Java SE 6 1.6.0_29-b11-402
    Telestream Episode 6.2.2.9 (3412)
    Can you give me a Tip?
    When I import the Clip in a Catalog, CatDV says:
    Import Notes: Movie contains invalid time values
    I added a new testfile in attachment. 3862_testversion6.2.2.93412h264mp41mbit16x9.mp4.zip
    I now use the ffmpeg to convert Clips into mp4. But it makes my Workflow complicated and slow.
    But maybe Squarebox can somehow find the way to use that files.
    Regards
    Leo
  • Brad Starkey
    March 20, 2012 at 12:38 am
    Sorry, I’ve been slammed and just saw this. I revisited my test. It turns out I was using Xuggle to play the proxy. In your media playback settings make sure Xuggle is checked. QT doesn’t work for me either.
    That might not be a solution for you. Can you get away with .mov? I believe Episode 6 is not causing the same problems with .mov’s.
  • Leonid Nekrasov
    April 26, 2012 at 9:43 am
    I’ve also informed Telestream about my problem. And after several mails I became post, that makes me hope 🙂
    “Leonid,
    We have made some progress with your issue. We beleive it will be resolved in an upcoming release. Our estimate is June/July timeframe. We believe the upcoming 6.3 release should resolve this issue.
    Thank you for your understanding and your efforts.”
    Regards
    leo
