Activity Forums Adobe After Effects Some image imports from Photoshop won’t show in After Effects
  • Some image imports from Photoshop won’t show in After Effects
    Posted by Tim Chan on September 5, 2014 at 3:42 am
    I’m creating an app and I used Photoshop. Imported the psd file into After effects. But somehow all the images won’t show, only text.
    I’m trying to animate it so it looks like a normal scroll up and down from an iPhone. But all the images which are off screen won’t show up once I drag it into screen but at the same time the text are all fine. What is wrong? I definitely imported the psd file correctly, since I did it with another project a couple days ago.
    Please help. Due date is Monday.
    The only thing what’s differnt is. The images are all in a clipping mask in Photoshop. All the circles are white shapes and I put the images as clipping mask to that.
    Tim Chan replied 12 years ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    September 7, 2014 at 12:02 am
    I’m not certain if Photoshop’s Clipping Mask feature is supported in AE. Try flattening one use of a Clipping Mask and see if this is recognized when imported into AE.
    Cheers
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Tim Chan
    September 7, 2014 at 1:06 am
    Ohh yea I figure it only shows Photoshop clipping mask if I import those .psd files in After Effects and it is actually already in the visible screen. All the clipping mask which I pull, drag or move from off screen into the visible screen won’t be shown.
    So I found out how to solve this problem. Before importing the .psd file I just resize the canvas size in Photoshop. I enlarge it so all the clipping mask are visbile in Photoshop already and not offscreen. Later I import the .psd file in After Effect and everything is there. The only thing I need to change then is the screen size in Composition Setting.
    THANKS 😉
