Activity Forums Apple Final Cut Pro Legacy some clips of sequence turn black arbitrarily in canvas
  • some clips of sequence turn black arbitrarily in canvas
    Posted by Mark Wunsch on January 22, 2010 at 8:36 am
    I keep having the problem of random misbehaviour of the canvas. Individual clips in a sequence or part of them show only black, random parts play within the next clip. Re-rendering may expand the black parts, putting a filter over all clips and rendering changed the pattern but did not cure the problem, actually it gets worse. Reopening: no change.
    Changing from safe RT to unlimited and back didn’t do the trick as recommended in a different posting. Something seems to be really screwing up.
    Any ideas? Thanks
    Mark
    Mac OSX 10.6.2, FCP 6.0.6, MacPro
    Charlie Key replied 16 years, 7 months ago 3 Members · 2 Replies
  • Rafael Amador
    January 22, 2010 at 9:48 am
    Hi mark,
    With the extensive info that you provide about your system, your format, your workflow and the kind of filters you are applying, is necessary a lot of imagination to give a diagnostic.
    Rafael
    http://www.nagavideo.com
  • Charlie Key
    January 22, 2010 at 10:26 am
    Me too Mark, which codec are you working on? I am on XDCAM EX 1080i50. It has happened once only and was there when I exported too, but not when I displayed in viewer. Odd.
