Activity Forums Apple Final Cut Pro Legacy some clips not showing up in log & transfer window in FCP even though they are in the Master file
  • some clips not showing up in log & transfer window in FCP even though they are in the Master file
    Posted by Linda Thornburg on November 20, 2011 at 11:21 pm
    I am using Log and Transfer in FCP to import P2 footage from a hard drive. Using Log and Capture because I need to keep a metadata user clip file name as the clip name. All of the clips show up in the CONTENTS folder. All 6 of the folders are there. All the parts of the clip show up in the appropriate folders, AUDIO, CLIP, ICON, VIDEO… But when I drag the Contents folder into Log & Capture only some of the Clips show up. None of the clips I’m looking for are “spanned”. And none of them shows up on any other clip that is imported, either before or after.
    I can drag the individual MXF clips into the FCP browser, but then they lose the metadata name/date/time I’m trying to keep.
    Any suggestions?
    Thank you so much,
    Linda
    Thank
    Linda Thornburg replied 14 years, 5 months ago 3 Members · 3 Replies
  • Steve Eisen
    November 21, 2011 at 1:50 pm
    Correct workflow will allow you to see your clips.
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Open the Root folder in Log and Transfer not the individual folders.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Christy Garland
    March 25, 2012 at 10:15 pm
    Hi Linda,
    I’m having this exact same problem, with your description matching my situation. All the folders are there, correct structure, but in L&T it only shows half the clips, and none of them spanned. Did you find a solution?
    Many thanks,
    Christy
  • Linda Thornburg
    March 26, 2012 at 5:21 pm
    Hi Christy,
    I think that I hadn’t hit “add file” in upper left corner of the log & transfer window.
    Sorry, it’s been so long since I had the problem, I can’t remember what the solution was.
    Linda
