Activity › Forums › Apple Final Cut Pro › Some Audio
  • Some Audio
    Posted by Richard Herd on April 3, 2012 at 3:30 pm
    I found this to be pretty useful, so I’m passing it along.
    I cut a dialogue scene in a CC, where all the audio was left alone. Then the cc plays in a storyline and that is where I added the fx, especially the compressor that I set to 50-50 and I drop the audio to -12. What do you know it is all at a perfect level. There was no reason to futz around with each individual audio clip. I could apply EQ to the entire clip–dare I say it? Almost like bussing! Note: I’m also very careful to set the roles and I for clarity’s sake, I use the Jim Giberti technique of general organization.
    Then I added FX and score, each of these were also a CC, to which I set levels and compressor setting at 50-50.
    Wow! It sounded really good. (And I cannot overstate how much easier was than legacy.)
    Richard Herd replied 14 years, 5 months ago 5 Members · 11 Replies
  • 11 Replies
  • Claude Lyneis
    April 3, 2012 at 4:15 pm
    CC means Combined Clip? Just checking.
  • Richard Herd
    April 3, 2012 at 4:25 pm
    Compound Clip…sorry.
  • Jeremy Garchow
    April 3, 2012 at 4:55 pm
    Closed Captioned. Color Correction. Chevy Chase.
    You know, the basics! 🙂
    If Apple can sort out the CC performance issues and implement a decent way to view the contents without losing sight of the entire timeline, they would go from pretty good to super awesome.
    Jeremy
  • Richard Herd
    April 3, 2012 at 5:10 pm
    CMD-[ and CMD-] is the short cut.
    [Jeremy Garchow] “a decent way to view the contents without losing sight of the entire timeline”
    I also keyword the CCs and then they are skimmable in the browser.
  • Jeremy Garchow
    April 3, 2012 at 5:17 pm
    [Richard Herd] “CMD-[ and CMD-] is the short cut.”
    Yes, to open and close the cc, but it doesn’t allow you to adjust the contents of the cc without losing the focus of the overall timeline.
  • Jim Giberti
    April 3, 2012 at 7:14 pm
    Yeah Jeremy, this is one of the things that would/will make Compound Clips really useful – especially for stuff like complex audio tracks where you need to go back a forth a lot during a mix to tweak individual clips.
    Probably the single biggest shortcoming of a great idea, is eliminating the context between the project and the CC.
  • Jim Giberti
    April 3, 2012 at 7:16 pm
    [Richard Herd] “I’m also very careful to set the roles and I for clarity’s sake, I use the Jim Giberti technique of general organization.”
    Thanks Richard, I’ve always wanted my own branded technique.
    Are you using a template to start like the one I posted?
  • Richard Herd
    April 3, 2012 at 9:25 pm
    [Jim Giberti] “Are you using a template to start like the one I posted?”
    Funny you should ask. The answer is yes, but your post was from October or so. I just assumed that’s how you did it. So your post the other day was exactly how I’d set up the audio. I guess I should’ve said something sooner.
    To be sure, I don’t set up the pseudo-tracks first, but I do set them up when I get to them. That is, I am very careful to keep all dialogue with the original media in a CC. Then I don’t touch it. When the scene is cut, then I effect the CC audio, not the individual clips. I found the enhancement tab to be extremely useful, a nice compressor for example was quick and effective on the whole “track.”
    After the dialogue was done. I created a quasi-track that I used for sound effects (lots of ocean ambiance in this particular cut).
    Today, I shall do the music!
    These pseudo tracks are all connected to a 5 second gap clip (a slate if you will) before the picture begins.
    FYI: 10.6.8
    Mac pro with 16 GB
    X-1.0.2 (Because multicam doesn’t matter to me, I didn’t update. Glad I didn’t!)
  • Richard Herd
    April 3, 2012 at 9:36 pm
    [Jim Giberti] “or stuff like complex audio tracks where you need to go back a forth a lot during a mix to tweak individual clips.”
    That’s what I assumed you avoided with your Technique. I was really working hard to create a bussing system. That is, when the track is set as the primary, I put the various clips in there according to role. I created my own roles also. So each primary is a series of clips of identical roles, which is what I did in 7 btw. I kept dialogue on 1 and 2, for instance. FX on 3 & 4 and so on.
    Then I make all of the clips on the primary an entire CC. And I only “mess” with the CC. First I set the dB to -12. Then I set the compressor in the enhancer window to 50-50. Then I apply EQ. I have not had a reason to jump into the clips. I can stay comfortably in the CC–which is also a Primary.
    It would be nice to CMD-] and then wherever the playhead was positioned in the CC, that’s where I would end up in the clip. Seems like an easy fix.
    Said it before, I’m gonna say it again: I sent Apple an enhancement note: Color Coded Roles not only do I want to define the role, I want it to be a definable color, so all my FX are RED–or whatever color I feel like.
  • Adam Helwig
    April 3, 2012 at 10:14 pm
    Two questions…
    1. What is the Jim Giberti technique?
    2. What do you mean when you say a 50/50 compressor setting for audio?
    Thanks 🙂
