Activity › Forums › Maxon Cinema 4D › Solving Texture Issue – un-uniform texture applied
  • Solving Texture Issue – un-uniform texture applied
    Posted by Alex Anderson on March 26, 2018 at 10:13 am
    Hello to All,
    i created a simple subway model , using just single plane and using extrude and bevel. BUT when i tried to apply texture to model, its not applied to all the surface , instead it choppy , some places its applied but on other its not at all.
    i have tried all the methods like cubic/flat/cylinder/uvwrap….. all give same result
    can some one help me , whats going wrong here ? i have attached the image , you can see in roof and walls there are patches where texture is not applied.
    just now i have started cinema 3d , so some tutorial on this issue is greatly helpful
    Learn..Learn..Learn
    Alex Anderson replied 8 years, 6 months ago 2 Members · 6 Replies
  • Justin Thomson
    March 26, 2018 at 3:49 pm
    You may have overlapping polys. Are there duplicates of the mesh in your scene?
  • Alex Anderson
    March 26, 2018 at 6:11 pm
    thanks for the reply
    not sure overlapping polys, how to find if its overlapping ?
    if these because overlapping polys then how to fix it ? or do i need to re-model the whole scene again ?
    Learn..Learn..Learn
  • Justin Thomson
    March 26, 2018 at 6:45 pm
    Can you share the file?
  • Alex Anderson
    March 26, 2018 at 7:12 pm
    its my first try on modeling , i am sharing file , but let you know its very much ad-hoc
    12294_subwaytrial.c4d.zip
    Learn..Learn..Learn
  • Justin Thomson
    March 26, 2018 at 7:20 pm
    “Main” and “SideWalls” are duplicates of each other and over lapping, hide one of them from render and viewport.
  • Alex Anderson
    March 28, 2018 at 7:39 am
    Thank you very much for you time.
    after your analysis i just checked and found that c4d slice command will create new poly but also retains from parent poly object.
    i have corrected that and now everything is fine. and btw i have used a free script from cgtools called perfect split now
    Learn..Learn..Learn
