[Solved] Can’t tell whether it’s computer capacity or is Cinema 4D trying to get under my skin?
Earlier today I was working on a project that I very much want to finish ASAP but it is one of those things where you have to get a frame render preview(s) before you decide to do a final Cinema 4D render.
So today I’ve finally reached that point and I’m starting to render my preview frames and going through the settings to optimize between the factors of time and quality.
Start getting some results and found my perfect space. (3-5minutes/1 frame)
Saved. Shutdown computer. Go out for lunch.
Come back within a hour later and open the same project. Now I decide to render a preview image again for the sake of double checking and the render time has nearly rose 4 times!
I decided the lower my settings and now the Global Illumination is well over 20 minutes!!
What is going on?!
I closed all my processes that were not required; I put a reset on my software and computer; Yet I continue to have the worst render times…
Any suggestions or help would very much be appreciated.
EDIT: One frame took 5 hours to render over night. Something is seriously wrong.
EDIT 2: It was my plugin! The plugin TurbulenceFD had my render going much longer then it should have.
