Activity › Forums › DaVinci Resolve › Solutions to Timecode Extents error in Resolve and FCP7 with Cineform
  • Solutions to Timecode Extents error in Resolve and FCP7 with Cineform
    Posted by Anmol Mishra on November 8, 2012 at 4:51 am
    Hi! I found a number of thread on this issue, but none solved my problem.
    I have stripped the sequence of speed changes or any filters.
    1. Exporting from FCP. Options include XML and EDL. Also Automatic Duck has a free XML exporter.
    I tried all 3 methods.
    I got the Timecode Extents Error in XML import.
    I got a “failed to import EDL timeline – No media-pool source clips could be found for this timeline. Cannot load EDL”
    2. Settings in Resolve 9.
    I tried
    Use Timecode -> Embedded in Source Clip
    Use Timecode -> From the source clip frame count
    Assist using Reel Names -> Source Clip Pathname.
    Assist using Reel Names -> Embedding in source clip file
    Assist using Reel Names -> Source Clip filename
    3. Changes in FCP projects.
    I have a Cineform 25P project and all the files are Cineform 25P.
    I tried to conform to 24P and then export. Same problem!
    I tried to click on every clip and press ‘f’ to Match Frame.
    I opened a new sequence and copied just the video files over..
    Its been 3 days and its frustrating me as I have to finish grading by the end of this month..
    Here are the relevant files –
    FCP xml – https://dl.dropbox.com/u/9906333/Rumba.xml
    Duck XML – https://dl.dropbox.com/u/9906333/Rumba-duck.xml
    FCP EDL – https://dl.dropbox.com/u/9906333/Rumba.edl
    Anmol Mishra replied 13 years, 10 months ago 1 Member · 1 Reply
  • Anmol Mishra
    November 8, 2012 at 5:36 am
    Interesting!
    I think the Match frame and overwrite helped a bit.
    Now when I import the XML I get a Reels do not match error..
    At least there is some progress..
