Activity Forums Adobe After Effects Solution to jittery motion of pans and text on Avids and or NTSC
  • Solution to jittery motion of pans and text on Avids and or NTSC
    Posted by 305artist on November 16, 2006 at 5:45 pm
    Render your project with Lower fields first and do 30 fps. I finally got smooth pans for broadcast. 🙂
    305artist replied 19 years, 9 months ago 2 Members · 5 Replies
  • 305artist Create COW Profile Image
    305artist
    November 16, 2006 at 6:37 pm
    …oh yeah, and import your footage as lower fields first in the Avid. Smooth as can be.
    305artist
    November 16, 2006 at 6:40 pm
    ” Now, why didn’t I think of that? I’ll have to go back to AE school, I guess…”
    I was having a problem with the 29.97 frame rate…which is odd because that is NTSC native…but Avid handled the 30 fps with much better results.
  • Chris Smith
    November 16, 2006 at 8:00 pm
    Thanks for the info, but I have to say that’s the first time I’ve seen someone have problems with it in the first place. You shouldn’t have to change the framerate. But lower fields is standard for the Avid codecs. I render out Quicktimes at 29.97 to the DS everyday with no problems.
    Chris Smith
    https://www.sugarfilmproduction.com
    305artist
    November 16, 2006 at 8:14 pm
    Im working on an Avid Adrenaline and I have been having major problems with the usual Animation>Frames setting.
    Charles Pazos
    Art Director
    Exit Media
    http://www.findexit.com
    305artist
    November 16, 2006 at 8:59 pm
    ..and I forgot to add that you need the filter “reduce interlace flicker” on your final comp. Without it, you will still get the stuttering motion.
    Charles Pazos
    Art Director
    Exit Media
