Activity › Forums › Apple Final Cut Pro Legacy › soloing deletes renders
  • soloing deletes renders
    Posted by Cee Dee on January 16, 2007 at 7:13 am
    im going to assume i dont know what im doing here.. there is no way that removing visibility removes renders… obviously i can always undo… but im sure there is another way to do this. any takers?
    Tom Wolsky replied 19 years, 8 months ago 4 Members · 4 Replies
  • David Roth weiss
    January 16, 2007 at 8:12 am
    [cls105] “im going to assume i dont know what im doing here..”
    Nope, this time you’re actually right, turning off a track does destroy renders, and undo doesn’t bring them back. This “feature” of FCP is a ridiculous programming error that has never been rectified. It alone makes the “Pro” in FCP a misnomer.
    In any case, the only workaround is to indivdually disable clips on the timeline by right clicking and unchecking enable.
    DRW
  • Tony Manolikakis
    January 16, 2007 at 2:35 pm
    Well Undo (CTRL-Z) doe bring them back. Turning off visibility and then turning it back on does not bring them back. I am sure that is what you meant. Man this can be a real pain.
    Tony
    Tony Manolikakis
    Rev13 Films
  • Cee Dee
    January 17, 2007 at 12:36 am
    i second that 🙂
  • Tom Wolsky
    January 17, 2007 at 2:04 am
    The application is designed to always render from the top down. It always renders from the original files. It never builds intermediate render files. That’s the way the application works. It’s hardly a programming error. It may be a different design concept from what you want, but it’s intentional, and for good reason.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
