Activity Forums Adobe After Effects solidworks to after effects
  • solidworks to after effects
    Posted by Hannah Gibson on September 24, 2009 at 12:47 am
    Hello!
    I have some 3d triangles made in Solidworks from a client that I need to take into after effects as a 3d object.
    Does anyone know of any way to get a 3d model out of Solidworks and imported into After Effects?
    Thanks.
    Hannah Gibson replied 17 years ago 30,359 Members · 2 Replies
  • Hannah Gibson
    September 25, 2009 at 5:52 am
    Thanks for your help David, I had tried to research this but clearly not well enough.
    They were already existing in Solidworks made by someone else so that’s why I hadn’t just done them up in photoshop to begin with, and I am worried to recreate them as I had real physical objects made from the Solidworks file and need the the computer version to match directly to the physical real world version. I didn’t want any depth or slight increments to change, so I thought I would just see if there was an easy way to get it over to After Effects first.
    Thanks again, Solidworks does and Universal 3d export so this is the go I would say.
  • Hannah Gibson
    September 26, 2009 at 9:10 am
    no 3d animation is intended, all i needed was the 3d object in after effects to map my 2D images and move the 2D images around in 3D space according to the 3d object.
    i am not trying to use after effects as a 3d program, i just needed my 3d object as a guide for mapping video to it.
    universal 3d file export out of solidworks has worked out too.
